TRW #315lb spring observations
Old Jan 5, 2021 | 08:41 PM
Mooser's Avatar
Mooser
That certainly is an odd one then, I had a #360TRW spring on the car and with the TA hanging (shock connected) you could almost press the end up by hand (I had to use a small floor jack of course) enough to get an 8" bolt through
Here is was without the nut on, the bolt being tilted enough to still hold it in place
Be interesting to hear what CC says
M
Old Jan 5, 2021 | 09:36 PM
Countryside Cafe's Avatar
Countryside Cafe
On mind, the hole on the spring is 1 1/2 " behind the hole in the arm. You have a different mfg. of spring also.
Old Jan 5, 2021 | 10:31 PM
Mooser's Avatar
Mooser
You should post a picture of your setup, (That picture is a TRW spring)
M
