Just installed new battery in 72 small block. The ammeter shows slightly to the positive of 0 under normal driving with nothing turned on. Should it be dead center? It gos to dead center with the headlights and blower on. Also put a rebuilt alternator on a year ago with internal regulator. Should I be concerned?
What Voltage do you read at the two battery terminals with the engine running at high idle? If it's in the vicinity of 14.0 Volts and your battery stays charged, I wouldn't worry about the needle indication on the Ammeter.
14.4 at idle isn't alarming, but IMHO 14.8 is too high. I'd investigate whether the Voltage regulator is properly adjusted (assuming it's even adjustable).
based on the OP's other posts he has a 1972 C3 so he is in the wrong forum but to confirm the topic of the regulator it's internal and non-adjustable. Would check the double wire connector on the alternator for partially broken or corroded connection.
The new battery is fully charged at 12.6 volts before starting the vehicle. Drove for 5 minutes and the amp gage was all the way to the right + side and did not move back to the center. Pulled in drive way and checked voltage at idle (650 RPM) 13.8 volts. Seems to me this is overcharging and the internal regulator is faulty. Does this seem right?
Installed rebuilt alternator, the ammeter still does not go back to 0 after being driven for. It is about a third of the way to the plus side. Is this still to much charging to the battery?
Please clarify what you are working on. Is it a 72 engine in C1 or C2 or is it a 72 Vette?
Does it have an internal or external regulator?
Are they any devices on when this happens? Do you have a large amp?
Joe
I believe I said it was a 72 small block, does sound that like a c1 or c2? Also stated it had internal regulator. No devices on. Was just replaced with a 63 amp alternator.
From: Putnam Valley, New York. Amateur Radio Operator K2NS
A 72 small block IS NOT A CAR---IT IS AN ENGINE. Don't be a wise guy. Wise guys get no answers. If it is a 1972 Corvette, then the post belongs in the C3 forum---NOT HERE !!!
You are the one who posted a question about a C3 here in the C1/C2 section, so don't blame people for asking.
With the engine off, battery disconnected, is the Amp gauge needle at "O".?
Sometimes the gauge gets screwed up and the needle gets "off".
The ammeter is measuring the voltage between two different points in the system. A poor connection or degraded cable will effect how it reads.
In my opinion the alternator is probably fine.
you ignored my earlier suggestion, post #5, to check the two wire plug for a hidden break which will effect regulator performance. When unplugged and a voltmeter is placed between ground and either number 1 or 2 wire in the plug you should get a non-zero reading.
Sorry, I did that and got something like 7.5 volts on the black and white wire (#2 terminal). The black wire was like 13.5.
