Best lemans style gas cap
Old Jul 2, 2016 | 03:42 PM
Bigeddie's Avatar
Bigeddie
Default Best lemans style gas cap
i realize that most are the "fake" ones but if you add a quick fill gas cap the illusion is there.So my question is who makes the best one for our cars?
Old Jul 2, 2016 | 05:28 PM
1Fordman's Avatar
1Fordman
Mustalgia makes one of the better ones, it mounts using the 4 stock gas lid mounting screws.
Old Jul 2, 2016 | 05:42 PM
RBrid's Avatar
RBrid
Actually at least a couple of us got one from Mustalgia recently: for my '77.
Good quality as far as I can tell. -R
Old Jul 2, 2016 | 08:28 PM
7t9l82's Avatar
7t9l82
Mine is the same as the mustalgia cap but I got it through a company that sells L-88 equipment like flares and FIA lights and covers, can't remember the name. They were first class to deal with.
Old Jul 3, 2016 | 03:50 PM
Bigeddie's Avatar
Bigeddie
soooooooo
Old Jul 4, 2016 | 12:39 AM
Jamess411's Avatar
Jamess411
I have Mustalgia as well….solid cap…fit very well….its the look I wanted so a good purchase as far as I am concerned
Old Jul 4, 2016 | 01:17 AM
The13Bats's Avatar
The13Bats
actually mine was the best
It was a prototype off liverpools racer
Mine is all fake poser,
I reworked the mounting, it bolts to the stock trap door hinge
I like that the flange covers the finger pull trough
Old Jul 4, 2016 | 01:48 AM
bmans vette's Avatar
bmans vette
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
I picked up one off a Viper.
Has the polished look instead of the chrome look.
I think I paid $100 for it a couple years back.
Have not mounted it yet.
It really comes down to personal choice....IMHO
Bman
Gone up since then.....as high as $700 (crazy)....
http://www.ebay.com/itm/Dodge-Viper-...pXNcRX&vxp=mtr
Old Jul 4, 2016 | 03:22 AM
LT1M21Vette's Avatar
LT1M21Vette
... if you add a quick fill gas cap ...
Anyone has a link for an early C3 quick fill gas cap?
Old Jul 4, 2016 | 09:03 AM
Neil B's Avatar
Neil B
http://stores.mustalgia.com/c3-corvette/
Old Jul 4, 2016 | 09:05 AM
Neil B's Avatar
Neil B
I recently bought mine from Mustalgia. I think the big difference with the Mustalgia piece is that it completely replaces the stock fuel filler door hinge and pivot. There are others on the market that replace the lid but still bolt to the stock hinge.
Old Jul 6, 2016 | 02:43 AM
LT1M21Vette
Originally Posted by Neil B
I meant this for early C3.
Old Jul 6, 2016 | 01:11 PM
bmans vette
I ment this for early C3.
That would be a great way to use the Lemans cap with the existing stock tank setup. The cap would just be a cover and not have a connecting neck all the way to the tank.
Anyone do it this way?
Old Jul 6, 2016 | 09:12 PM
The13Bats's Avatar
The13Bats
It's a great looking piece my turn off was it leaves the finger divot and that makes it look unfinished of not thought out to me,
When I reworked mine from Liverpool mine uses the stock hinge,
But for plug and play the mustang one is about it.
I do not believe they make these for the older larger mouth tanks only the unleaded fuel tanks, and I scored a couple of these at a garage sale for .50 still in the package to flip on ebay, I had to look up what they fit in doing so I learned a lot of people had bad luck with these busting and parts going in the tank....
Old Jan 2, 2020 | 02:18 PM
Dustin James's Avatar
Dustin James
Where did you get the plate/flange below the gas cap?
Old Jan 2, 2020 | 09:08 PM
Pzark's Avatar
Pzark
I went the hard route and machined a mounting plate
which is now part of the deck. Filler is fully functional and bolts to the plate. Mine came from a racing outfit who are not a supporting vendor so shall remain nameless.
Old Jan 2, 2020 | 09:53 PM
moodswing's Avatar
moodswing
Pzark How did connect that cap to your tank or are you using a fuel cell.
To Best lemans style gas cap
Old Jan 2, 2020 | 11:31 PM
RBrid's Avatar
RBrid
I happen to have taken this picture of my Mustalgia yesterday - it's just sitting in its hole here:
Old Jan 3, 2020 | 03:10 AM
Pzark's Avatar
Pzark
I used a fuel grade hose with a hose clamp on the tank neck, typically used on older cars and it was a really good tight fit. The length of hose was such that the gas cap underside neck would slide into it and be proud of the attachment flange on the car body by about 1/10”. I had a large O ring at the top of the gas cap neck. As the gas cap gets screwed down it compresses the hose onto the O ring and seals of the connection, the hose is only about 3” long and a good 1 1/2” is on the tank neck and about 1 to 1 1/4” on the gas cap neck so it is pretty stiff. It works really well with no gas fumes or leakage even when it is standing on a hot day. To fuel I simply lift the top and gas up the tank. My tank is vented so it does not build up lots of pressure as in a sealed system. But other guys get the same look using a simpler method by making the Le Mans cap part of their gas flap. I just wanted a fully functional set up plus its a project for me. Hope this helps
Pete
Old Jan 3, 2020 | 06:43 AM
Dazaa Rafae Aman's Avatar
Dazaa Rafae Aman
Are the Lemans style caps wider than the standard fuel door? I really want one but also need to fit a luggage rack so not sure if it will open or not
