Key Buzzer Switch ID
1973 Chevrolet Service Manual has an excellent Troubleshoot section on those specific conditions that can cause it, but not too detailed on the pictures of the switch close-up.
Pretty much shot it down to the switch, but never to have seen a new switch, I need your help with this.
As far as the gaps: If the switch's Clip doesn't sit fully onto the switch, I can see the switch not seating fully down into position in it's receptacle.
And the last photo: Is that the normal appearance of the switch where the Lock Cylinder's protruding buzzer activator tab makes contact?
Thanks very much for any assistance.
Steve
Have you tried placing continuity probes on the long switch contacts and trying to depress the internal contacts to see if they open and close correctly?
I am not sure what that silvery part is in the third picture. I wouldn't think that it should be there.
As to the fitment of the clip on the switch, I don't have any parts to compare if that is normal or not.
Are you sure that your problem isn't the plastic lock cylinder tab that might be stuck in the extended position.
Hope that these ideas help,
Jim
Thanks Jim. If you mean the "window" where the Lock Cylinder Key Tab contacts, NO. I take it that it's normally open unless the key is in the lock and not in the RUN position, correct?
That's just a reflection from light in the photo. Clear plastic.
It could be, but it, and another cylinder lock I've tried appear to operate normal on the bench.
Jim
Steve
I really like pictures to help jump start my feeble mind.
And i appreciate your insight too.
Thanks again.
Steve
Bad switch.
Cost for one of these: just South of a C-note.
Therefore, I had better, at least, make an attempt to possibly repair it.
The end of the switch where the contact strips merge had to be shorting, and I noted the lower strip bent up an RCH so as to perhaps cause this erroneous function.
I ever-so-carefully used a jeweler's flat screwdriver to pry the two strips apart, with a little success.
Brushing and spraying electrical contact cleaner into the merging contact area was also done, and at the end of all this, the upper arm contacts of the switch now have an ohm reading of infinite at rest, and lightly pushing on the contacts through the switches opening yields continuity. The only question as I see it now, is will the Key Lock Cylinder's actuating tab work with the switch's broken cover tab? It did before I tore the column apart. At least I can test it by just installing the turn signal switch & hook up the negative Battery Cable to see.
My fingers are crossed.
Steve
And Thanks to Jim Shea for pointing me in this direction.
Hey, that's what I was lookin for!
Yeah, I see now that missing plastic end on mine. The fact that the buzzer worked correctly before the column rebuild gives me hope that the switch might still work like before. I can see the purpose of it, but not the necessity of it, as long as the actuating tab (non-conductive) in the cylinder lock reaches long enough to push the contacts together. It had to have, since it worked before.
Please! Not another 90 bucks!
Steve
Looks like that broke-off end of plastic tab is critical, and looks like another 90 bucks for me.
Just installed a new Lock Cylinder, with the Buzzer Switch already in place. Unfortunately there is continuity between the contacts in all Ignition Key positions as well as the desired "Key removed" position. Perhaps the Lock Cylinder's square casting "key" caught the Buzzer Switch's exposed contact strips on insertion, causing the closed circuit. They sat up awfully close to the edge of the "hole" where the Cylinder fits into.
The only other thing I can do right now is remove and re-insert the Buzzer Switch, so as to check the contact's condition AND subject the contacts to the different direction of contact with the Lock Cylinder.
And maybe place a tiny section of electrical tape over the exposed contacts to serve the function of that broken tab end.
Just shootin' in the dark here folks.
Steve
Addition: Buzzer Switch/Clip doesn't wanna come out with the Lock Cylinder in place, and I'm not gonna force ANYTHING at this point. (Yes, with the Ignition key out or the Ignition Switch in "RUN".)
All this might prove is the importance of that broken Buzzer Switch tab end.
Steve
