82 coolant temperture sensor probloms
Old Jul 7, 2016 | 12:49 PM
Stevie1982's Avatar
Stevie1982
Default 82 coolant temperture sensor probloms
I take the sensor out and go to the parts store. They have to order one. I come home and put it back in now car wont start. I smell gas. It acts like its out of time. I tried moving the distributor. Still wont crank. Anybody have any input?
Old Jul 7, 2016 | 01:08 PM
MelWff's Avatar
MelWff
why did you take the sensor out?
did you mark the original position of the distributor before moving it?
did you disconnect anything that would have prevented power going to the distributor?
Old Jul 7, 2016 | 01:36 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
I have a couple questions and some suggestions.
1. Why did you take the CTS out?
2. Did you know that you cannot just turn the dizzy without first disconnecting the EST wire?
Now for my suggestions.
1. All that's needed for the CTS if the one you removed was original is a two wire weather pack type. It is much better than stock.
2. The dizzy is HEI and is controlled by the ECM. So if you did not disconnect the wire, the ECM will constantly readjust the timing electronically.
Do you have a 82 corvette GM service manual? If not, get one. It's a huge wealth of information on troubleshooting a CFI motor/electrical issues. It fully shows how to troubleshoot the problem you are having.
Here's a little tip on CFI. If you have an issue that sets the CEL, that's means that the ECM is not happy with the input from that system and sets the error code. In that case "always" troubleshoot starting with the first code number displayed and then work in order from there. If you still have an issue and no CEL, the ECM is happy and it is more than likely to be a mechanical issue that the ECM doesn't care about, monitored or concerned with. There also can be a conditions that the ECM seems ok, no CEL, but is bad.
I hope this helps.
Old Jul 7, 2016 | 01:50 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
BTW... the coolant sensor will not prevent your '82 from running, just running correctly. You have more going on than just the sensor.
Old Jul 7, 2016 | 04:12 PM
Stevie1982's Avatar
Stevie1982
I hope this helps.
The only thing that got disconnected was the CTS. Someone posted on here that if you unplug the CTS the EMC would read it as a default mode and still run. Weell, not mine!
To 82 coolant temperture sensor probloms
