I just ordered new shocks for my 76 and I am seriously looking forward to getting them installed. I bought the car two years ago but I do believe the originals are still on the car. I have read many recommendations for Bilstein shocks and I found what I think was a really good deal on a set of Bilstein Heavy Duty and they are on the way to me. I have also read that the removal of the rear shocks can be difficult and I would love to gain some insight on what to expect from all of you who have done the job. Thanks in advance!
Start right now spraying the bolts/nuts with PBblaster. Spray every day until the new ones get here. The upper bolt on the rears are in a tight space. Fronts are cake. Pull the rear tires for better access. Note the position of the washers on the lower rear. Shelve the original shocks if you can. NCRS restorers will need them some day, and will pay.
Thanks! I began the spraying weeks ago and if the rears come off with ease then I will be very grateful. I believe I have read that some were having major issues with removing the rear shocks from the lower mounts and were recommending buying the shock mounts before beginning installation.
Reason: wording
what you read is that the lower shock mounts are difficult to remove not the shocks themselves, you do not need to remove the lower shock mounts to replace shocks
Thanks! I knew the lower mounts typically didn't need removing but I must have been mistaken in reading the rear shock inner bushings had a tendency of completely rusting to the lower shock mount therefore necessitating the need for the new lower mounts. I now have renewed confidence that this job will go smoothly! I will keep the PB Blaster flowing for now.
Sometimes the shocks mounts are really ****ing close to the frame is the hard thing. I had more trouble with the fronts than the rears. the fronts i had to use a jack to compress the ****ers while putting them in. The rears I left the cable tie on until i seated the lower part, then "Sniped" the top of it in the mount bracket. put a thick screw driver in the top of the bracket so you can have leverage if you miss the snipe with the bolt going through the hole.
