new gauges update
Old Jul 9, 2016 | 12:52 PM
tgcattle's Avatar
tgcattle
Default new gauges update
I just installed my new gauges in the center console of my 79. They are autometer artic white. Oil pressure, water temp, volt meter, fuel and clock. Took first ride this morning to check out function of the gauges. All worked fine................However I did have one glitch. Seems like every time I do one thing I mess up something else. Well the headlights decided to open all by themselves. I turned on the lights and then off and they closed. also the with the a/c on the air will not switch to the upper duct only to the floor. I suppose I disconnected something?? somewhere??
any ideas?
thanks
Terry
pink/blk to gauges +
pink to fuel sender
orange to clock +
grey to gauge lights +
black to ground -
Old Jul 9, 2016 | 04:50 PM
mikem350's Avatar
mikem350
If your 79 uses vacuum to control the vents, then there is a small hose that got disconnected or broken. Goes to the control switch.
Old Jul 9, 2016 | 04:58 PM
tgcattle's Avatar
tgcattle
Guess I'll have to open her up again
Old Jul 9, 2016 | 05:36 PM
NewbVetteGuy's Avatar
NewbVetteGuy
Where's the pictures of your gauges? Can't wait to see them.
I could see doing replacement gauges some day but I'd really want some sort of small, attractive custom plate that I could put over the branding that seems to inevitably come with all aftermarket gauges. -A C3 or even C7-style corvette logo over the maker's branding would be PERFECT, IMHO.
Adam
Old Jul 9, 2016 | 07:02 PM
havesometo's Avatar
havesometo
Old Jul 10, 2016 | 08:18 PM
tgcattle's Avatar
tgcattle
Old Jul 23, 2016 | 02:24 PM
tgcattle's Avatar
tgcattle
I disconnected the temp control manifold when I put back together. Plugged it in, all better nie
Old Jul 23, 2016 | 02:41 PM
7t9l82's Avatar
7t9l82
Did you just use a Drexel to make the pods round? The bottom of each pod is flat or did they slip in and did you trim the back. I've had a set of the Phantom II gauges ready to go in but have been too lazy. Maybe this winter. Nice job,maybe other pictures?
Old Jul 25, 2016 | 08:36 AM
tgcattle's Avatar
tgcattle
I used a 2in hole saw
Old Jul 25, 2016 | 09:06 AM
SH-60B's Avatar
SH-60B
Did you put the "warning" lights back in? You need the "ALT" light.
Old Jul 25, 2016 | 11:11 AM
tgcattle's Avatar
tgcattle
No warning lights. I have gauges instead of lights
Livin on the edge I reckon
Old Jul 25, 2016 | 11:24 AM
wendellp601's Avatar
wendellp601
It's my understanding that a light, or some other form of resistance is needed for the alternator to work correctly.
Old Jul 25, 2016 | 01:25 PM
tgcattle's Avatar
tgcattle
I never heard of that
Old Jul 25, 2016 | 05:22 PM
SH-60B's Avatar
SH-60B
The alternator needs to see the resistance through that bulb to initiate charging. That bulb left me stranded once with a discharged battery I'd be very curious to see what the system voltage is when the motor is running. You should see between 13.8 and 14.2 volts. You'll want to do this with a DMM for most accurate reading, but the Autometer gage should be a good indicator of whats going on too. But DMM would be best.
Old Jul 25, 2016 | 07:21 PM
tgcattle's Avatar
tgcattle
The voltage is as you said I can hook up the bulb if it is necessary
Old Jul 25, 2016 | 07:39 PM
tgcattle's Avatar
tgcattle
My light says gen.
Old Jul 25, 2016 | 10:35 PM
canadianroaddog's Avatar
canadianroaddog
Navigator
Did you change out the tach and speedo as well? If so what did you use?
To new gauges update
Old Jul 26, 2016 | 09:54 AM
SH-60B's Avatar
SH-60B
That's the proper voltage, so your car has no issues
Old Jul 26, 2016 | 01:16 PM
tgcattle's Avatar
tgcattle
I have seen some white overlays for the stock speedo and tach. I dunno
Old Jul 26, 2016 | 04:53 PM
SH-60B's Avatar
SH-60B
My light says gen.
I believe thats right, my bad
My experience was that light did not come on at startup, I didnt notice it until the motor was missing badly, down on power, and and the voltage gage read below 12V. After the tow home I recharged the battery, then noticed the GEN light did not come on with key on, and the alternator was not charging when started. Took the bulb out, filament looked fine, replaced into socket, and it worked again. Started the car and the alternator was charging again. All I can think of is some light corrosion at the contacts.
