Back of dash.
Old Jul 13, 2016 | 06:25 PM
ThePabst's Avatar
ThePabst
Default Back of dash.
I'm replacing the plastic circuit trace plate, I need the trick for the three Tach. contacts.
Old Jul 14, 2016 | 12:05 PM
MelWff's Avatar
MelWff
have you watched the Willcox video?
Old Jul 14, 2016 | 12:20 PM
ThePabst's Avatar
ThePabst
Thanks for the tip! Actually, I was replacing the plastic circuit board on the back of the dash... the one that powers the lights and such. I could not figure out how to release the clips, and subsequently the trace plate...
It took a little fussing but I simply, carefully, worked them out with a med screwdriver and a pair of needle nose.
Thanks for the test procedure, I will use it! Does the Speedo needle come off the same way? Both needles are faded and I'd like to paint them while I have things apart.
Brian
Old Jul 15, 2016 | 03:20 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
How to remove the tach needle the safe way.
After assembling the speedo, you'll see me re-set the needle only I goofed and had to pull it off again so if you watch this video it'll show you how to safely pull the speedo needle.
To Back of dash.
