Rebuild T/T steering
Old Jul 14, 2016 | 08:45 AM
V4motorsports's Avatar
V4motorsports
Default Rebuild T/T steering
Quick question....
How do I lock the steering shaft? When I put the Lock Plate Removal tool on the steering shaft and try to depress the lock plate, the shaft sides up with the removal tool. The lock plate doesn't depress.
Any ideas?
Russ
Old Jul 14, 2016 | 01:03 PM
MelWff's Avatar
MelWff
look through the various Jim Shea articles on steering columns on this site
http://jimshea.corvettefaq.com/?cat=5
Old Jul 14, 2016 | 01:10 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you need the special made lock screw for this.
basically a 1/4" screw with a square head ground on it. it is the only way.
Old Jul 14, 2016 | 01:49 PM
V4motorsports
I took a 1/4 bolt and cut the head off. Then ground a slot in it, to act as a screw. Tightened as tight as I could with a screwdriver, will try a bolt. Maybe can get it tighter with a head on it.
Russ
Old Jul 14, 2016 | 10:32 PM
Jim Shea's Avatar
Jim Shea
Use a 5/16-18 NC set screw or a #20 Allen screw. Thread the screw into the upper steering shaft in place of the star screw. That will lock the upper shaft from moving as you use the tool to compress the lock plate.
Jim
Old Jul 14, 2016 | 11:07 PM
69Vett's Avatar
69Vett
opps Jim is correct I stated the wrong size thread.
Old Jul 15, 2016 | 06:58 AM
V4motorsports
Thanks for the help guys! That did the trick!!
Russ
To Rebuild T/T steering
