I have an unstarted motor that I'd like to crank over but the carb needs a rebuild before I do so (stuck throttle linkage). Turns out that in order to do it "properly" I need to know the application specs, which includes stuff like camshaft lift and duration.
Is there a way to get these numbers without pulling the cam out? Maybe a stamp on the outward-facing end of it or a measurement I can take?
OTOH, since it's a QJet maybe just setting to factory specs would be a decent starting point.
never heard of anyone ripping open the timing cover to see if perhaps there are ID numbers on the front of the cam just to have a carburetor rebuilt. The rebuilder based on the carburetor number should have no problem checking to see if it has the stock jets and metering rods, etc. and based on how emissions restrictive the carburetor is adjust the jets and rods to a more performance oriented tune. If you insist on knowing the specs you will need a degree wheel and dial indicator to measure the cam specs.
Thanks!
Chris
You can rebuild it with out the specs, it might take a little more tuning to reach the end goal.
Yeah, I am thinking I'll start stock and tune later, but it's nice to know there's tools to measure the cam while installed. Any pointers to using the degree wheel and dial indicator to get these measurements?
Since the QJet is dynamically metered I think starting at stock will be fine for a while. I just wanted to know if there were tools to measure internals of the engine without having to tear it apart.
You could measure the lift with a dial indicator on the push rod tip and use a degree wheel and dial indicator to measure the duration, alot of work, the end of the camshaft might have a part number, but that's also a lot if work and unless it's a rowdy cam you'll be fine just going with stock I'm that spot on the order form. Once you talk to the carb builder, just tell him it has a cam that doesn't seem big but isn't quite stock.
