Install of DynoMax Headers
If I go there is it a big job for them to install with all the brackets and everything?
How much? How much time?
It depends mainly on how well the headers fit. Some guys are able to unbolt the exhaust manifolds and bolt on the headers.... Even then, you will either need to cut the front exhaust pipes to fit, or fab up some new ones.
Other guys, (like me :) ) can't even get the stock driver's side exhaust manifold off!!! And if the headers don't fit just right you have to start banging them with a hammer so they will clear whatever it is they are hitting.. so the difficulty of the job can vary quite a bit. I don't know what brackets you are talking about. MJ
tnt76vette: Frankly, I do not think you understand the purpose of this forum! :nonod:
What Mfr sells this abortion of a header? Cause I'll certainly never buy a pair (should I find myself in need) I'm sorry but that just sounds like shoddy design to me. The thread is about dynomax headers are they really like that? man I would be seriously hot if I had to modify my clutch linkage to fit a set of economy headers.
Admittedly there isnt a ton of room in there but a slight move of the tube would eliminate the need to cut up the clutch linkage.
[Modified by fauxrs, 8:13 PM 9/10/2002]
I wish more people would lend a hand and treat others as they would want to be treated, overall the entire forum would benefit as a whole :D :cheers:
It woulda been much easier if anyone didn't have anything POSITIVE to add, to simply not add anything at all :)
Maybe he wanted to get an idea of cost prior to going to the shop so he doesn't get ripped off.....
Maybe a person can enjoy the thrill of a vette, yet be unable (for various reasons ;)) to complete their own mods ;)
This is supposed to be a community of people helping people, especially on a day like today....some repsonses suprise me :(
[Modified by Mean Green 2000, 8:03 AM 9/11/2002]
Let's see here. I have a job that I haven't done myself and I'm not sure how difficult it is to do. Nor do I know how much I should expect to pay to have someone else do it. Rather than go to a local shop and have them charge me an arm and a leg simply because my car is a Corvette, I could first check with a forum that has thousands of members, many of whom have either done this work themselves or paid someone to do it. Then I can go into a shop and have enough knowledge in hand to know what to expect and to know when the guy is BS-ing me or not.
That sounds like a perfectly reasonable use of the forum to me.
OHSIXX,
The header install itself should be pretty straightforward. They'll slide right up from the bottom. I think the Z-bar (clutch bellcrank) was the only real obstacle in my car. At least once I removed it to put the header on. I can't imagine them charging more than an hour of labor to do that. Swing by, we'll tackle that part no problem. :D Might be a long drive home to florida with open headers though :eek:
My car is non-AC though. With the AC on yours, I'm not sure what brackets mount to the exhaust manifold. I'd suspect that any header company expects that and has brackets that should bolt right on.
Now the pl;ace where I'd be concerned about the $$ is the cutting & fitting to the existing exhaust. I've got no clue what they should charge for cutting & flaring the existing exhaust.
Good luck!
OH YEAH....make sure you drive around a coupla days with headers uncapped. It's a life-changing experience.
[Modified by Brettmc, 9:55 AM 9/11/2002]
