Pump gas with 11:1 compression?
Old Jul 21, 2016 | 03:26 PM
  #41
NewbVetteGuy's Avatar
NewbVetteGuy
Originally Posted by gkull
A magneto looks like a tall distributor. Tall because the lower section is a generator (power source) and the top was a dual points under a rotor cap. They generally had locked timing and no vac advance. I was a pit crew person and at a young age I thought how stupid!!!!!!
Ok wow, I didn't know those existed; that's such an odd way to try and get spark when every gasoline car already has a perfectly good alternator...
Adam
Old Jul 21, 2016 | 03:30 PM
  #42
a striper's Avatar
a striper
Originally Posted by NewbVetteGuy
Regarding spark plug heat range; you're saying that switching to a cooler spark plug could drop temps a bit and reduce engine knock risk, or would a hotter spark reduce knock risk because you'd get a faster burn?
Adam
Colder plugs to prevent the plugs from becoming an unintentionally early ignition source. This can be a big deal in forced induction applications but I've benefited from it in NA engines too.
Old Jul 21, 2016 | 03:33 PM
  #43
The Money Pit's Avatar
The Money Pit
Originally Posted by a striper
I'll dig into the distributor to see where I ended up. I agree with Kubs about the advantage of having the timing controlled by a programmable computer. I have an MSD Digital distributor in the 11.5 car. IIRC it gives 20 different mechanical timing curves and ten vacuum curve by turning two dials. I knew setting up the ignition curve would be tedious with this car and today's gas. I have an MSD Boost retard box in a 6-71 car with 9.5:1 compression. I like that better because I can create any (even non-linear) curve I want. As I mentioned the curves that worked well in the first four gears were too much for overdrive. I bet if higher octane was available I could speed up the curve and pick up some mileage. I do pay close attention to feedback the car is giving and never overload it at low RPM. I'm pretty sure that somebody could hurt this engine if they did not know how to drive a high compression set up. This would be an appropriate case for drive by wire that would not allow overly aggressive throttle application in high load low RPM conditions.
I built a 10.7:1 377 for a friend with similar set up. It had something like a 3.4 ring an pinion with the same .64 OD (mine's a 4:11). We could get down to 1500 RPM in fifth with his. By 1800 you could ease in the throttle and start pulling quite well. His cam was similar but 112 LSA vs my 110 LSA, installed with four degrees advance vs my two degrees. His also had a Performer RPM Air Gap vs my Victor JR with a 1" spacer.
I think his typically gets 2-3 more MPG than mine. I get about 14 consistently. I'm in the Ozarks and the hills hurt the mileage and are a factor in the ignition curves. I've tuned cars that are pretty happy right up until we try to climb a hill in OD.
I don't feel so bad about my 12 mpgs now that I hear you're getting 14 with an OD trans.....My cam is a 108 LC, which only makes things worse.
I know what you mean about hurting the car if you don't know how to drive it. I took the power steering and power brakes out, put in a full manual reverse vb trans, and loud mufflers to keep the wife out of it.
Old Jul 21, 2016 | 03:45 PM
  #44
cv67's Avatar
cv67
St. Jude Donor '05
some equate lugging the motor with "saving" it drives me nuts riding with someone who does that
eesh, its a performance car what are they thinking
Old Jul 21, 2016 | 04:00 PM
  #45
a striper's Avatar
a striper
As long as you are only giving light throttle application a lot of performance builds can run well below 2000 RPM in overdrive. BUT if you mash gas down there you're asking for trouble. Since I started adding OD to old school cars I've found that tuning for low RPM in OD takes the majority of my time and effort. I am looking forward to playing with the cammed LS3/T56/Megasquirt that I put in a '69.
Old Jul 21, 2016 | 05:02 PM
  #46
99 Black Bird TA's Avatar
99 Black Bird TA
Running 10.85 to 1 compression in my Dart 400. No issues if the temperature is under 90 degrees. If it's over 90 degrees and no or very low humidity sometimes get a slight ping on 93 octane pump gas.
Old Jul 21, 2016 | 06:30 PM
  #47
bluedawg's Avatar
bluedawg
Originally Posted by The Money Pit
Over the past several months I've been wrestling with the idea of upgrading the AFR 195 heads(non Eliminators) on my 406 to the new 210 Eliminators.....and I think I'm about ready to pull that trigger.
The question I have is chamber size options. I now run 75 cc chambers, and with that I calculate a 10.1:1 compression ratio....verified by my machinist years ago. I run a flat tappet solid cam with 254@.050 duration, and 36 degrees locked out timing. Never pings, starts like a new car, and overall performance is great. The 210's are available with either 65, or 75 cc chambers, and I am tempted to try 65 cc to raise the compression to 11:1, and for the mean time....keep the same cam.
I'm thinking it'll work fine because of the cam duration, but want to hear from those that are running similar combinations. Also in the future I do plan on doing a solid roller cam, but with less duration, so that needs to be considered also. And really long term.....a 427 short block,.....but the wife doesn't know that's coming yet.
You need to figure the dynamic compression ratio, 8 to 8.1 is the highest you'll want to go with out running into detonanation issues and if you stay between the 7.9 to 8.0 you should be fine. With that being said, why the bump in compression if your not planning on more camshaft, the bump in compression by its self is worth 3% in horse power gains so if your making 600 it's 18 horse on just the compression. Now then if your going up in compression to go up in camshaft the just keep your dynamic in check and you'll be fine and the gains of all three would net a large gain.
Old Jul 21, 2016 | 09:25 PM
  #48
hugie82's Avatar
hugie82
Many options can hold off pinging. Keeping the engine at 160-170 degrees, aluminum heads, new cam with more duration and if the motor is apart. Knock down any peaks or edges.
Most new performance oriented cars are running 11:1 without any problems. 93 octane is your best bet but I know some areas don't offer it.
Old Jul 21, 2016 | 09:30 PM
  #49
The Money Pit
The reason for my post was to find others that are running 11:1 cr with large cams and on pump gas.....and if they are experiencing any pinging issues on pump gas. The cam I now have called for 10.5 :1 and my current head/piston combo nets 10:1. Since I planned on a head swap anyway, and have the option to boost compression.....why not? But if the replies to this post were not positive.....I can opt to keep the same 10:1. The increased head port size and flow ratings alone will boost power,....just thought I'd also try and better match the cam too.
Old Jul 21, 2016 | 09:35 PM
  #50
The Money Pit
What size cam? What timing curve?
When I originally started trying to recurve the timing I had similar results when it was super hot out.
Now I have a 1 1/4" tube dual core aluminum radiator and run a single 16 inch Spal fan, and a 160 T-stat. Pretty much stays at 160 unless it's over 90 degrees out, and I get stuck in traffic.
Old Jul 21, 2016 | 09:45 PM
  #51
bluedawg's Avatar
bluedawg
The thing is that new performance cars have a computer and a knock sensor and have the ability to retard the timing, so if the computer detects detonation it retards the timing back enough so that it don't ping. Plus the computer takes 5 to 7 readings per second from the o2 sensor and keeps the fuel in the zone that the engine runs the best and avoids detonation, going lean will cause detonation in short order. My 6.2L in my sierra is 10.5 to one and I've only heard it ping once and that was with crappy fuel and pulling a trailer out on the Denali highway with lots of tall hills. Technology is amazing these days. Guys like Pauldana and Diehard(Tony) have the fast fuel injection systems on their hot rod and all though I don't think that they have knock sensors, their fuel system keeps the fuel ratio optimized and if it werent for the price that would be the way to go. I can put a blower on my truck with the 10.5 to 1 and between the knock sensor and the fuel system run 6 to 8 lbs of boost, it would be so tough to do that on a antique fuel and timing system even with a meth water injection and boost/timing retard box.
Last edited by bluedawg; Jul 21, 2016 at 09:47 PM. Reason: Third grade pucktuation and shittty spelling...Awe crap forgot my add meds again.
Old Jul 22, 2016 | 02:11 PM
  #52
v2racing's Avatar
v2racing
My 406 in my signature runs 11.8 to 1 compression ratio. I haven't got the 75 Vert running with this engine in it yet, but I put a few thousand miles on it when it and the 700R4 were in my 80 Vette. I ran it on 93 octane and had no problems.
The squish is set tight, .034". A tight squish (quench) helps, as does a very good cooling system and very careful tuning. Cold air intake helps a lot too, although I did not have one on the 80. The 75 I have an L88 hood with functional air chamber.
The engine likes a somewhat rich idle, 13 to 1, at part throttle cruise I ran 14.2 to 1, and wide open 12.8.
Timing was 16 initial with 6 degrees of ported vacuum and 34 degrees total all in at 3000.
The only time it ever pinged was once when I got stuck in a traffic jam with the temps in the high 90's. When I first got moving from the traffic, it pinged, but after moving down the road a ways and cooled down, it quit pinging.
These are the specs my engine liked, they may not work as well for another combination. I got great gas mileage, tremendous throttle response and it ran like a scalded dog!
Old Jul 22, 2016 | 03:35 PM
  #53
v2racing's Avatar
v2racing
Sig didn't show up last post. I post this then it shows up??????
406", Ported Brodix -10 Heads, 225cc, 2.100"/1.600" valves, 11.8 to 1, Ross Ultralight Pistons, Custom Solid Roller, 650/609 lift 248/252 dur 110 LSA, Comp 1.6 in./1.5 ex. Extreme Gold Rockers, 7/16 Studs, Stud Girdle, Heavily Modified and Ported Victor Jr., Modded 750 Holley, Jet Hot Coated Hooker Super Comp Headers, 3" Mandrel Bent X Pipe Exhaust with 2 Chamber Mufflers, Art Carr 700R4, 3500 stall lock-up, Super Ten 4.11 posi,
Old Jul 22, 2016 | 05:16 PM
  #54
NewbVetteGuy
I thought that there was an "ideal" range for squish/quench and being in that range helps with pinging, and that being either OVER (as the L48 and L82s were from the factory) or under increases pinging / premature detonation risk.
I've heard that the "ideal" was a .040" quench, but I realize it's probably not that simple and is probably a range with .040" in the center of the range.
Adam
Old Jul 22, 2016 | 05:22 PM
  #55
NewbVetteGuy
Wow! And WHAT a signature! That's some serious air pump you've got there!
You have a dyno chart posted anywhere? I bet it looks FAN-TAST-IC.
650 intake lift?!?!
Adam
Old Jul 22, 2016 | 05:33 PM
  #56
v2racing's Avatar
v2racing
650 intake lift?!?!
Adam
The tighter the better for squish. In race motors I used to build I would tighten the squish until the piston would shine the head a little, then back off a couple thousandths.
I don't have a dyno on the motor in this iteration. It made 560 HP and 530 torque before I hopped it up.
Old Jul 22, 2016 | 07:04 PM
  #57
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Newbie, mine also has a small quench of 0.036.
V2 that is quite a nice build!
To Pump gas with 11:1 compression?
Old Jul 22, 2016 | 07:38 PM
  #58
NewbVetteGuy
I had no idea. The smallest squish I can get is 0.040" with the FelPro 0.015" gasket. I'd have to have the block decked to go any lower, but with a static CR of 10.2:1 and aluminum heads and my dual snorkel CAI, I think I'd have to do something seriously wrong when selecting a CAM to have this end up being a problem, even with Washington State 91 Octane.
Adam
Old Jul 22, 2016 | 07:48 PM
  #59
jb78L-82's Avatar
jb78L-82
Adam
My L-82 355 with AFR 180 64CC heads, howards roller cam (.525/.525, duration 219/225, LSA 110) JE Forged Racing pistons 9:1 with a total compression of 10.2:1 (Felpro .015) has zero detonation with 89 octane fuel....I also run the dual snorkel L-82 cold air intake with no pinging in any gear, any RPM, any temperature outside.....
Old Jul 22, 2016 | 11:50 PM
  #60
NewbVetteGuy
I've seen your build quite a few times; I'm just hoping to get as close to replicating your build as possible without touching the bottom-end and going with cheaper Profiler heads vs. AFRs. It's great to hear that you can run 89 octane with an incredibly statistically similar setup to what I have planned.
-I've been so impressed with the power you managed to get and even the power you got out of your stock, one bad cylinder L82 before you rebuilt the bottom-end and replaced the top-end.
Out of curiosity, what intake are you using?
Adam
