I have been a member of the forum for 8 years but don't normally ask questions. Everyone out there has had the answers I needed on the forums. The original compressor on the AC unit burned up and was smoking. I unplugged it and removed the fan belt so it wouldn't catch fire. Now it is time to replace the unit and other parts as needed. I do not need to go stock on the replacement. Not much else under the hood is stock any longer so why bother. What is the better Compressor to use as a replacement? I assume the AC Reciever/Drier will need replaced also. Everything else was working before the R12 Freon all leaked out. Anyone out there have a list of parts that will work? Or should I just go stock and not modify anything???
This may be an opportunity to make the change to an efficient compressor running r134a. I did the underhood kit (compressor, brackets, condenser, hoses). The Sanden compressors make a world of difference.
If your compressor locked up, you will have some extra work to do. The evaporator at a minimum will have to be flushed out. This is something you can do at home with a flush kit, but make sure every part that is staying with the old system is thoroughly flushed. You will also have to use a new VIR or get a VIR eliminator kit. You need to research this a bit to come to the right decision, though. I'm not a fan of the VIR eliminators, but that's just my opinion.
It's really not that hard of a job and except for having the hoses crimped by a pro a/c shop, it shouldn't take more than a weekend to do the job.
I did an a/c replacement on my 74 recently. I got the compressor from Autozone $197, a VIR eliminator assembly from Corvette Central $719. The VIR eliminator kit had all the lines and fittings for 134a Freon. It is a plug and play system. It does require quite a bit of disassembly, and it's not cheap. But the air is cold.
Do you have a part number or model on the compressor?
That is expensive. I will have to go faster w/the top down
Found the Nostalgic AC Parts kit #CK-1000 is a little more economical ($599) but will likely need more working of the hoses to fit properly. I haven't started the project yet. The garage is in the 90's in Southern California if you can believe that.
Your help is always appreciated.
I did a complete ac restoration and up grade to 134 on my 72 with Classic Auto Air in Tampa FL outstanding job. I pull out entire system (ac box, evaporator,dryer, hoses, compressor etc) they check all parts rebuild all original and upgrade to 134. Get a quote 813-251-2356
