C-3 Fuel pump problems
Old Jul 21, 2016 | 01:35 PM
vette626469829713's Avatar
vette626469829713
3rd Gear
Default C-3 Fuel pump problems
Hello all! I'm a first time user with a 43 year history in owning corvettes. My 82 car, which I purchased new has a problem with the fuel pump and not wanting to start. Last summer the car started back firing along with dying out along with a ruff ideal. Then car would not start so I replaced fuel pump. Car starts runs ruff so I replaced fuel filter, no difference. Could not resolve problem it was late in the season stored car for winter. This spring car would not start so I checked the 10amp fuse on the main panel and it was fried!! Bad!
I replaced fuel relay and the fuse, car cranks no fuel coming out
So, I ran wire from battery charger, (12volts) to the brown/white strip wire on fuel pump connection on tank? Car starts and runs. Has anyone experienced this problem or know how I should proceed? I checked the wiring under the car that runs from relay to the tank, it seems to be fine.
Thanks for your help!!
Old Jul 21, 2016 | 08:21 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
So, the question that I'm assuming you are asking is has anyone had problems with the wiring on the tank?
So, I'll ask...
Have you check if you are getting power back at the fuel pump?
Is your fuel gauge working, if so your connections are probably good but if not, you may have connections or grounding issues at the pump.
Have you double checked your grounds
Did you replace the pump with a factory pressure or did you upgrade to the 85-89 version with MUCH higher pressure which will solve your running rough. I upgraded my pump and it runs like a totally different car.
Old Jul 22, 2016 | 10:37 AM
vette626469829713
3rd Gear
Thanks for your response! Gauges work, checked grounds, replaced pump but did not upgrade. I'm not getting power to the pump. Once I connected battery charger to pump, car started. No power is coming from relay connection to the pump.???
Old Jul 22, 2016 | 10:54 AM
billschroeder5842
If you are getting power at the relay but not at the pump, you have a broken wire.
Test this by running a wire from your relay to the pump. If it works you need a new harness.
Old Jul 22, 2016 | 02:13 PM
vette626469829713
3rd Gear
That is where I'm headed. Just wanted to know if someone else has had to deal with this problem. Thanks again
To C-3 Fuel pump problems
