Low HP L71
First...an L-88 cam is not going to idle at 750 RPM or lower...at least not happily. The L-88 cams REALLY like headers and OPEN exhaust. Mufflers of any sort take a lot away from it. A 427 with an L-88 cam and rectangular port heads isn't going to be a low end rocket....but with 4.11's it should still be pretty darn strong...especially from 3500-4000 on up. That cam is going to want to make power at 6500+ RPM if things are right.
12* initial is way too low. Need to ck total timing without vacuum. With decent gas in it I would expect it to be best with no less than 36* total....and most likely 38*-42* with the old heads. The more initial you can put in it and limit the total the better. Idling with 20*+ will help response a lot.
Any idea if they took compression out of it when they rebuilt it? Sure sounds like it.
Time to do a compression test. Maybe the cam is installed a tooth off?
I'd get timing handled first....then verify carbs are opening and go from there. The L-88 cam isn't a complete deal breaker...but it's not a super nice street cam.
JIM
I can tell you that my 427/400 made a LOT of fan noise and an ancient Car and Driver confirms it......
When I changed out the pathetic 2" exhaust that all 69' Vettes came with to a 2 1/2" chambered system and set timing to 38 degrees total....this car TOOK OFF......night and day.....
Jebby
Jebby
To answer a couple of the questions in case it sheds any more light .....
I am in the UK.
The engine was rebuilt by Gellner Ohio, from what I can see the head cc was measured and recorded as 112 before milling, and compression measured after at 10.6:1 although its only recorded once.
The camshaft is Crane #968561 = 3925535 grind (L88 replacement) with
MA992 solid lifters
Triple carbs rebuilt by Holley Perf IL (although I had to fit a critical missing vac. o ring)
At 3500rpm full throttle ( I have reset middle carb butterfly opening travel to full) there is a normal progressive acceleration up to 4500 rpm or so (I don't want / shouldn't need on the street, to rev any higher) albeit relaxed - no wheelspin, no kick.
Yes its does idle at 750rpm, lumpy / rolling but will sit there, no attempt to stall.
There is a bit of hesitation in pulling away around town speeds and the car prefers more throttle at low speed than is normal....
It has factory cast headers and a very subdued / quiet exhaust system, its 2 1/2" with a single tailbox each side.
Haven't measured dynamic advance but the dizi weights & springs are in situ and free.
From what I can tell in photos the vac pick up for the f/r carbs is high up on the centre carb and not the pick up point under the float bowl that is currently connected to the air pump and choke vac - tell me if this is wrong, maybe the carbs aren't seeing the correct vacuum. I did check the diaphragms for splits, they look OK, the springs seemed to be marked in orange.
Thats about all!
PS did anyone successfully fit a 'quiet' fan (electric or otherwise) as I'd rather be hearing the engine / induction noise than a very noisy but works superbly viscous fan!!
Thanks!
I am in the UK.
MA992 solid lifters
Thats about all!
I am in the UK.
MA992 solid lifters
Thats about all!
