Top End Kits
I cant plant a crate motor right now $$ However ,I can budget $2 K for some bolt on fun. I thought I had it ,with the Edelbrock Kit # 2022.Matched components ,til I was informed intake was too high for my hood. Need some help with putting this together. Thanks
Since you have a tight budget you might think about something along this line.
Intake Manifold, ZZ4, Dual Plane, Aluminum, Natural, Square/Spread Bore, Chevy, Small Block, Each $238.97
Trick Flow Specialties TFS-30310001 - Trick Flow® Super 23® 175 Cylinder Heads for Small Block Chevrolet
Cylinder Head, Super 23® 175, Fast As Cast®, Assembled, 1.250 in. Springs, Chevy, Small Block, Each $550.00
Total $1,338.97
It won't be a killer combo, but with the correct cam it will be a big step up from your stock L48.
The very first thing I would do is ditch your stock exhaust manifolds and get full length headers with true dual exhaust. This is worth a substantial amount of horsepower.
Next, you need some good flowing heads (I'm considering the NKB heads from Skip White. Some people aren't big on Skip White, but essentially he buys bare cast aluminum heads and then puts some quality valves, springs, and retainers in them. Cost is about $700 a pair), a better cam (the stock L48 cam is crap for making power), and a cheap low-rise dual-plane intake.
You should be able to do all of that for under $2k if you shop smart and it will make quite a bit more than that 310hp edelbrock kit. I would advise you to do some research and ask lots of questions before you buy anything, I'm still learning, but there are a lot of experienced people on this forum who can help you out if you ask nicely.
Total $1,338.97
Also, Summit Racing has other manifolds too that are more inexpensive, but I can't tell you if they will fit under your stock hood.
- Desired RPM range you will operate the car in
- The heads your going to use along with the valve springs
- Carb type & size
- Manual or Auto (what stall converter you are going to use)
- Rear end gear ratio & tire diameter
- Approx. weight of your car
Trickflow, Edelbrock, GM, Summit Racing, Jegs, .... lots of cams to choose from. Might just call Trickflow and see if they have a cam designed for those particular heads - would reduce chance of getting a mismatched setup. You will want to make sure the cam is compatible with the valve springs to avoid valve train issues.
The advice above about the valve springs is good.
Since my voodoo cam is a flat tappet and has an aggressive lobe design I opted to buy the recommended springs from lunati for the valves.
