Car been stable up untill the last few daze, but driving to the store just now AFTER changing the stat, the stupid thing is still going nutz on temps....~230f at idle in traffic on a lousy 2 mile round trip....makes no sense....been checked with a IR gun....I know the dash gauge is about 10f high, but it reading 240++ temps??? fans are on....Rad seems to circulate good, and looks clean inside from what I can see.....
trick is, after changing the stat 2 daze ago, I drove it around the burb, and no issues....leveled out at ~180f and so fine.....
I thought.....350 200 4r, one of them mini starters....another issue,
Use the ir gun to check inlet and outlet temps of the radiator. A high temp drop indicates poor water flow, a low temp drop indicates poor air flow.
On heavy equipment, I look for 9 to 13 degrees temp drop with the thermostat open and at operating temp. Higher or lower is a problem for a well designed system.
new stat failing. replace it.
you could have trapped air, had to fill mine 3 times to resolve running hot.
to completely fill with no Air. just put radiator overfill hose into a full 1-2 liter bottle.
be sure hose is fully submerged, run and warm cycle and let cool a couple times.
it will push air out, and suck in liquid it needs to completely fill system.
after several warm T-stat opening and cool down cycles it should be good to go.
