'79 OEM Radiator Help
From 76 to some point in 79, 3035856 was the radiator supplied when HD cooling was ordered. This was a 1 1/2" inlet radiator. During the 79 model, GM switched all of their radiators over to the smaller, 1 1/4" size inlets. From that point forward, 3043087 was the HD radiator. I've never seen a date or VIN, when the change occurred, but I've always suspected that it was late in the model year?
An L-82 with air conditioning, automatically got the HD radiator, V01 was only offered as an option on L-48's, or L-82's without AC.
From my previous post:
3035856
1976 - 350, w/hi-performance (L-82) & air conditioning, 2nd design 76, code ML, 1 1/2" inlet.
77-79 - 350, w/spl hi-performance (L-82) & air conditioning, 1st design 1979, code ML, 1 1/2" inlet.
77-79 - 350, w/HD radiator (V01), 1st design 1979, code ML, 1 1/2" inlet.
3043087
79 - 350, w/hi-performance (L-82) & air conditioning, 2nd design 79, code FW, 1 1/4" inlet.
79 - 350, w/HD radiator (V01), 2nd design 79, code FW, 1 1/4" inlet.
Thanks for checking. The judging manual states that the same radiators were used for both AT and MT cars; however, the fittings for the automatic transmission cooling lines were plugged on manual transmission cars. So, unless there's something special about the plugs, I may be able to use one of your AT radiators after all. Can I impose on you to check the broadcast codes to see if there's an 'MJ' among them? Thanks for your help.
Phil
I'll try to get a better look at them in the next day or two.
That would be great. Thank you.
Phil
Here's the breakdown of the radiator usage from 76-79, starting winth the 76 2nd design (the same radiators were used from 76-79).
3035558
1976 - 350, except hi-performance (L-82), 2nd design 76, code MK, 1 1/2" inlet.
1976 - 350, w/hi-performance (L-82) w/o air conditioning, 2nd design 76, code MK, 1 1/2" inlet.
77-79 - 350, except HD radiator, code MK & MJ, 1 1/2" inlet.
77-78 - 350, w/air conditioning, except hi-performance (L-82), code MK, 1 1/2" inlet.
3035856
3043087
3043083
79 - 350, except HD radiator (V01), codes FP & FR, 1 1/4" inlet. * This radiator doen't carry the note in the parts book, that it was 79 2nd design, but having the smaller 1 1/4" inlet, would make it a 79 2nd design radiator.
