Heater core advice
Old Aug 17, 2016 | 07:46 AM
yyz1970's Avatar
yyz1970
I replaced mine on my 72 (no air) with a made in mexico one from corvette central
No problems,all from under the hood
Old Aug 17, 2016 | 05:38 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
I would take any new core and test for leaks, then I would have the tubes reinforced with additional solder, because the connection point is where they typically begin to leak, especially after someone starts yanking on the heater hoses to remove them.
I use a razor blade to cut off hoses, to avoid stressing them. don't forget to reinstall the brace that holds the tubes in place. ... protecting them from Hose yankers !
you do not want to rip the dash area apart, unless you absolutely have to. good luck.
Old Aug 18, 2016 | 07:41 AM
jb78L-82's Avatar
jb78L-82
Non AC you do it from the engine side and it is plug and play...AC cars require removal from the interior..big pain!
