Quick Caliper Question
Old Aug 16, 2016 | 09:37 AM
V4motorsports's Avatar
V4motorsports
Default Quick Caliper Question
Rebuilding front calipers....the one on the right front is sleeved, the one of the left front is not sleeved.
Can I still use the "O" ring kit in the unsleeved caliper? I don't see any score marks in it and the pistons were nice and tight.
Russ
Old Aug 16, 2016 | 09:50 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Russ
They are the same diameter so I don't see why not.
Old Aug 16, 2016 | 09:53 AM
V4motorsports
Thanks CA-Legal,
I was thinking the same thing but when it comes to the brakes or steering, I really want to be right!
Thanks again
Russ
Old Aug 16, 2016 | 01:15 PM
teamo's Avatar
teamo
I think the only issue might be if there is corrosion on the piston bores which is a concern with unlined caliper bores.
Old Aug 16, 2016 | 03:54 PM
V4motorsports
There wasn't any corrosion but replaced the caliper anyway. There was a problem on one of the lips and I wasn't happy with the way the seal fit.
Everything is good now.
Russ
Old Aug 16, 2016 | 05:01 PM
GUSTO14's Avatar
GUSTO14
Russ, it's actually quite rare that an original caliper would have survived this long without already having been replaced with a sleeved one. Especially one without major corrosion inside.
I bought a '77 new back in the day and within 3 years was already having to replace a front caliper due to leaking. The SS sleeved calipers were just becoming available from the aftermarket at that time.
Good luck... GUSTO
Old Aug 16, 2016 | 05:10 PM
V4motorsports
Good luck... GUSTO
Gusto,
It wasn't an original but when I rebuilt the right side, I could tell right away that it was sleeved. This one didn't look like the right one. I took the left one to NAPA and bought one from them and you could tell right away that it was sleeved also.
The one I removed may have been sleeved, but sure didn't look it. Any way, it is replaced with a sleeved one and new "O" rings installed.
Russ
To Quick Caliper Question
