Turn Signal Lever Issue
Old Aug 16, 2016 | 09:55 AM
SideWinder3355's Avatar
SideWinder3355
Default Turn Signal Lever Issue
I installed a new smaller diameter steering wheel on my '69. I have the standard steering column. The new steering wheel is shallower and my knuckles hit the turn signal lever. Does anyone make a turn signal lever that will work with the shallower steering wheel, with less angle at the mounting point? Turn the turn signal lever backwards? I tried bending one and it snapped, made out of cast metal.
Gus
Old Aug 16, 2016 | 07:39 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Gus
Gus-
To my knowledge there is not any aftermarket turn signal lever you can use. However, you might try heating the lever with a torch and then re-bend it. You'll probably cook off the chrome when you do this but I'm sure if you get it glowing enough it'll bend where you need it.
Willcox
Old Aug 17, 2016 | 08:36 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Did you try your idea of flipping it over? Just curious if it would work
Old Aug 19, 2016 | 01:11 PM
SideWinder3355
Rescue Rogers, Yes, that is exactly what I did! AND, it works great. Plenty of clearance for my fingers and plenty of distance to the dash. Most wouldn't even notice it.
Thanks!
Gus
Old Aug 19, 2016 | 09:19 PM
Rescue Rogers
Good job!!!!
To Turn Signal Lever Issue
