Used block
Old Aug 17, 2016 | 07:25 PM
cocoa312000's Avatar
cocoa312000
Default Used block
Think of buying used block to build a little stronger motor for my 1980 L 48, found one used with new flat top pistons but block has been bored , He said forty over. Is this not quite a bit? $250 apparently has crank in it. Is this good price up here in Canada. He changed his plans and went another route said it has about 25 miles on it. Any concerns about flat top pistons and head selection? Thanks for your reply. and time.
Old Aug 17, 2016 | 10:28 PM
cv67's Avatar
cv67
St. Jude Donor '05
Id buy something from RockAuto before an unknown used or "rebuilt" out of the paper
Old Aug 18, 2016 | 08:41 AM
gungatim's Avatar
gungatim
.040 is no big deal. as for used blocks and guys who decide to "go another route" after putting all the time and money into a motor, I personally would assume the worst. meaning there is likely some problem with it, he forgot oil, cracked, shoddy work, who knows...I would pass.
Old Aug 18, 2016 | 11:15 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
25 miles and yank a perfectly good engine, doesn't happen. Go to a good speed shop and pay $250-300 from them for a block.
They will make sure the block is OK and it is peanuts compared to the entire build and you have piece of mind knowing you can take it back if anything goes wrong. Insist on paying by credit card another way of dealing with a problem with the engine.
Old Aug 18, 2016 | 02:33 PM
BlackC3vette's Avatar
BlackC3vette
At .040 over now, if there is a problem with one of the cylinders and you need to bore the block again, I would see that as a problem.
Old Aug 18, 2016 | 03:52 PM
cv67's Avatar
cv67
St. Jude Donor '05
x2 on ads that say "went another route". thats code word for its fubared and need to unload it. Otherwise if it was good why would they sell it?
Somethings wrong
Most machine shops got plenty of good inspected cores laying around their shop. Safer bet than most
Old Aug 18, 2016 | 03:58 PM
bluedawg's Avatar
bluedawg
I agree the if there us an issue at .040" over then you've got very little room to work with and like e every one else has said all you ha e to go off is the seller word which if whom you don't know, buyer beware. And I also think that if you stud your block or go even further and do a 4 bolt splayed mains with billet or nodular iron caps with the inner bolt studded you got the beginnings of a bullet proof bottom end, BK built a 383" out of his 2 bolt probably making 450 horse runs low twelves with probably 200+ 1/4 mile runs & it holds up. Like some one has mentioned you can buy a block ready to go from the machine shop, but if your block is in good shape you can build it to live at 600 horse.
Old Aug 18, 2016 | 04:02 PM
cocoa312000
ITs a friend of a friend. supposed to be because of heads or rods were not right or something is why he went different route. He says block crank and pistons are good. Thanks again for your time, and opinions.
Old Aug 18, 2016 | 05:05 PM
BlackC3vette
If it was recently bored with new pistons, rings, bearings, etc.. it may be worth the time to ask some more questions and get back to us with the answers.
Old Aug 18, 2016 | 09:58 PM
bmans vette's Avatar
bmans vette
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
Find out WHO did the work and talk to them directly.
Old Aug 19, 2016 | 06:58 PM
brick1234's Avatar
brick1234
Somethings wrong
People's minds due change I had a 400 block bored 10 over and ended up selling it a few months later when an almost free ls1 came out of my friends camaro when he totaled it. But due agree in a sense since alot of people will say anything to sell something so due I believe 25 miles and yanked no
Old Aug 19, 2016 | 10:17 PM
lvmyvt76's Avatar
lvmyvt76
we used to bore block .60 over to get more cubic inches that way.
Old Aug 20, 2016 | 09:56 AM
cv67's Avatar
cv67
St. Jude Donor '05
I get the changing mind thing believe me
What pistons are in there. how far in the hole?
Without that you dont know what head to get, compression ratio to shoot for etc. Perhaps he made that mistake of not checking who knows
Will he let you bring it by a machine shop to be checked out first before buying? that would instill a little confidence.
Know of a place for about a grand you can get a fresh shortblock. It wont be anything fancy but for a cheap motor-Buddy uses them, puts a nice ported Brodix head on, a 200 shot bit solid flat tappet and runs 10s wiht it. Blows the shortblock gets another one all the old stuff goes back on it. Forged piston up grade 100.
Not something I would do but he goes fast on budget.
Old Aug 21, 2016 | 07:33 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
pistons make all the difference, for me forged pistons are mandatory,
Hyper tech pistons = problems down the road literally.
flat top pistons are not performance pistons. rods stock ?
crank, cast or forged ? big difference if you plan to build performance.
.040 overbore, means you can safely rebore only 1 more time to .060.
I would disassemble and inspect everything, if all looks good reassemble.
If I were planning a performance build, I would pass on this.
Old Aug 21, 2016 | 07:54 PM
gerry72's Avatar
gerry72
$250 for a shortblock that may or may not be sound is not worth getting worked up about. Buy the thing, find out what issues it may have, and from there decide if you want to fix the problems -if any. It may be just fine (good machining, good parts and assembly) and a very good deal. There are no issues with flat top pistons whether they are sand-cast, hypereutectic, forged 4032 or 2618. Your L-48 uses a sand-cast dished piston. Any head you would use on your L-48 will be better with the flat tops due to slightly higher compression. A .040 overbore isn't a problem. Really, this could be a great buy or a waste of $250, which isn't that much to put at risk.
Old Aug 22, 2016 | 09:23 AM
anesthes's Avatar
anesthes
Somethings wrong
I blow stuff out the door at huge discounts because I'm constantly changing projects. Some guys are like me.
The key is to inspect the parts and ask the right questions.
I've never sold anything that I didn't think was 100%. If I have a part or something that is questionable, it goes into the scrap pile. I know a lot of people are not as honest as I am, but I wouldn't dismiss all sellers.
-- Joe
Old Aug 22, 2016 | 09:29 AM
anesthes's Avatar
anesthes
Sure it does. Not common, but it happens.
I sold a set of AFR 195's a few years ago that had nothing but idle time on them, because I decided to go a different direction (210s with larger chambers).
I build a 355 for a 4x4, had it dropped in and cam broken in and then another (much nicer) truck fell into my lap. I decided to part the truck out and sold a motor that essentially had about 3 miles of drive time on it.
Inspect the parts, ask the right questions. But even worst case scenario, look at the sum of the parts. I'd pay $250 for a .040 over motor with good crank, rods, pistons. Even if something happened I could probably re-use 80% of the parts, so base the price on that. If it's $1,000 worth of parts it's a good deal. if it's $300 worth of parts walk away.
-- Joe
Old Aug 22, 2016 | 04:37 PM
cocoa312000
Gonna try and see it this week. Apparently he bought a different car. Best friends buddy has it so not complete stranger. I went to school with him just did not know him that well. He said he paid $250 for pistons new and $500 in machine work.
To Used block
