80 fresh air vent
Old Aug 20, 2016 | 10:32 AM
BlackC3vette's Avatar
BlackC3vette
Default 80 fresh air vent
Regarding the air vent right under the top of the passenger side front fender, what position(s) on the control switch sends vacuum to the actuator?
The unit works, I tested it with vacuum.
Old Aug 20, 2016 | 12:45 PM
SwampeastMike's Avatar
SwampeastMike
That's not a fresh air vent--at least not in the way I believe you mean.
Air does not come out of it at any time. With the control set at "MAX A/C" vacuum is applied and most of the air used by the system comes from inside the cabin--i.e. recirculation. At all other settings there is no vacuum to the actuator and outside air for the system comes from the passenger side of the windshield wiper well.
Old Aug 20, 2016 | 01:05 PM
BlackC3vette
Well, that's why I just called it an air vent. Being at the passenger end of the wiper well, it defaults to the open position. So, the max a/c setting is the only time it gets vacuum and uses recycled air from the cabin. Thanks!
To 80 fresh air vent
