Windshield frame is all ground down and fitting nicely - pics inside
Old Sep 14, 2002 | 09:09 AM
NHvette's Avatar
NHvette
Default Re: Windshield frame is all ground down and fitting nicely - pics inside (paul79)
Thanks again for all the well-wishes and compliments.
Neil - everytime I see your sig, it reminds me of Neil Pert - of the band RUSH.
They are coming to NH in November. I've never seen them, but I've
already spent enough $$ this year on concert tix. Maybe I can win some.
I've got a couple CF members coming over today, so off to get things done
before people start showing ....
:seeya
Old Sep 14, 2002 | 01:33 PM
dash8's Avatar
dash8
Default Re: Windshield frame is all ground down and fitting nicely - pics inside (Daves_rusty_75)
hey dave, if you would like a hand. i'm not to far away.be more thanhappy to lend my limited knowlege. :yesnod: i'll even bring some brew :cheers: chris......
Old Sep 14, 2002 | 09:48 PM
CF6873's Avatar
CF6873
Dave, Are you only going to butt weld the post or are you also using sleeves? Based on what I have learned being in and around the Body Shop business for 30+ years I would use sleeves under the joints. You could drill a few 5/16" holes and spot weld the sleeves to the lower section and then slide on the upper section and spot weld the sleeve to that. Then you can weld the butt joint. This would make the joint much stronger in case of a collision or rollover. Looks like you have done a great job fitting it together. Good Luck, Craig
