My 80'C3 has no two hook, best advice needed.
Gentlemen, been at it five years but I'm still a rookie with alot to learn ! Turns out, my 80' C3 has no tow hook as I learned when my car shut down on a test drive. The three "A" car club said "we can tow it out of here but you need to sign a waiver absolving us of any damage that we might cause your vehicle.
Since this was a much modified car that was being parted out , I don't expect to be able to restore it to numbers matching or anything close so what would the best suggestion be for a solid tow hook install ?
Corvette Elders please advise.
Thank you again .
Robert
Thank you again .
Robert
Received 1,469 Likes
Cruise-In II Veteran
When towing from the front you put more weight on rear axle which can sometimes get clutch packs to operate when the tow truck turns. All the towing services I knew always towed vehicles with a limited slip from the rear or used a slide back. Most towing services today use slide backs so for most a non issue.
