any tips before i drop the transmission
Old Sep 13, 2002 | 10:31 PM
java0881's Avatar
java0881
Default any tips before i drop the transmission
tomorrow i will start the removal of the tranny.i need to replace the clutch and while i got everything out , i will also rebuild the M22.i was hoping somebody could give me some tips on the whole procedure.i will be using jackstands(which doesn't make me exactly comfy) :rolleyes:
thanks for the input
Old Sep 13, 2002 | 10:52 PM
redvetracr's Avatar
redvetracr
Default Re: any tips before i drop the transmission (java0881)
java,
I have a tip for you "eat your WHEATIES" !!
...redvetracr
Old Sep 13, 2002 | 11:00 PM
java0881's Avatar
java0881
Default Re: any tips before i drop the transmission (redvetracr)
thanks redvetracr,but i had more technical advice in mind :lol:
Old Sep 13, 2002 | 11:46 PM
lbell101's Avatar
lbell101
- Unbolt the driveshaft U-bolts and pull DS away.
- Remove yoke for extra room.
- Unbolt the mounting at rear of tranny. Two exhaust ubolts hold one bracket on. A couple bolts go straight up at the mount. A couple more in that same area are installed horizontally. Two more bolts are horizontal just below the u-joint on the backside. Two more bolts come down from the top but are under the shifter mount. Jack, wiggle and swear as needed.
- Remove 3 shift linkages at the tranny.
- Remove lower shifter to mount bolt from below.
- Remove console insert.
- Remove shifter boot.
- Remove upper shifter to mount bolt from up top.
- Pull shifter out through the console.
- Remove any loose brackets at rear of tranny.
- Remove shift lock cable at top rear corner of tranny.
- Remove some sort of switch mounted to the drivers side of the tranny.
- Remove 4 bolts from tranny to bellhousing.
- Pull tranny back and up over crossmember.
- Drop it out at the front.
- Unbolt bellhousing.
- Remove linkage and spring from fork.
- Pull off bellhousing and snake between exhaust to remove.
- Unbolt and remove clutch assembly.
Old Sep 14, 2002 | 03:31 AM
Stevo81's Avatar
Stevo81
WOW...good job by Larry!! sounds basic, but don't "drop" the trans. It is so easy to crack the case, and then you gotta get a new one $$$ A couple pieces of rope could keep it from slipping thru greasy hands. And do be sure the jackstands are good...We don't want to read about you...
good luck :seeya
To any tips before i drop the transmission
