82 Electrical question
Old Sep 9, 2016 | 10:38 PM
icpr4u's Avatar
icpr4u
Default 82 Electrical question
I have been having battery charging, among other, issues so in poking around with the multi-meter I have found that the red wire from the back of the alternator is grounded out. When I attach the meter to that lead and any ground or bare metal there is zero resistance.
Silly question, but this is not what it supposed to happen, correct?
I don't seem to be able to trace where it goes.
The service manual makes it look like it heads to the starter solenoid where it meets up with the battery cable.
Old Sep 9, 2016 | 11:17 PM
vbgod1's Avatar
vbgod1
an ohmmeter is not intended for checking live wires. It would be used on a unpowered circuit to check continuity, so you have the right idea, wrong application. If the alternator wire were grounded, I imagine it would blow a fusable link, or possibly burn the wiring up.
If your battery cables and alternator connections are clean and tight, not knowing what tools you have, I would run it to the parts store for a free charging system test. I would want to know alternator output under load in amps, and the condition of the battery. That would give you a starting point for further testing.
Old Sep 9, 2016 | 11:30 PM
icpr4u's Avatar
icpr4u
Sorry. Don't think my post was clear.
The battery is out of the car. I have been seeing voltage irregularities among other things while driving and connected to winALDL. The alternator is out and ready to be tested.
I was just looking for broken or corroded wires.
I am just looking for help tracing that wire to look for a short
Old Sep 10, 2016 | 12:52 AM
icpr4u's Avatar
icpr4u
Default more info
forgot to add
-the ALT is putting out around 50v while running....not amps... VOLTS (yikes)
- The reading at the battery while running will max out at 12.1v
-I tried to verify with my timing light...it reads volts as well and it jumped from 17-5v at the alternator.
-winALDL is showing a reading of around 6v or around 18v
Old Sep 10, 2016 | 06:32 PM
vbgod1's Avatar
vbgod1
Found an online wiring diagram, and I can't be much help. Looks like any wire with red, and power, is connected to this. alternator, starter, high blower....
I have never seen 50 volts, 15 is normally too high. At 50, I would suspect the internal voltage regulater. And yet, how can the single red output wire at the alternater show 50 volts, and the battery 12.1, when the diagram indicates this is the same wire? Fusable link good?
Old Sep 10, 2016 | 06:44 PM
lvmyvt76's Avatar
lvmyvt76
you could rebuild that alternator real easy & cheap! if it is the original, keepit and have it rebuilt if you are not able to do so.
Old Sep 11, 2016 | 12:35 AM
icpr4u's Avatar
icpr4u
I had the ALT and BATT tested at autozone today. I watched him test it twice and it passed both times.
I suspect that I may have had the meter in the wrong setting.
I believe the fusible link to be good.
i'm chasing another electrical short. once I get that sorted out i'll report back my findings on the ALT issue
Old Sep 11, 2016 | 06:07 PM
SIXFOOTER's Avatar
SIXFOOTER
Check the 2 wire plug that goes in the side of the alternator. 1 of the 2 wires comes from one side of the GEN light bulb. If you ground that wire the gen light should come on if the key is on. That will tell that circuit is working. Should be a brown wire I think. The other small wire should be red and have battery voltage all the time, it comes from one of the fuse links at the starter. I suspect that IF you are really getting 50 volts out of the laternator you have a problem with the red small red wire
To 82 Electrical question
