MSD 6A install location??
Old Sep 15, 2016 | 09:14 PM
fms93gt's Avatar
fms93gt
Default MSD 6A install location??
I am going to install the MSD 6A and I am searching for the best location. The engine and transmission are out of the car and I don't see anywhere in the engine compartment that looks like a good mounting location. I am considering installing it under the drivers seat.
Does anyone have a suggested location that worked well?
Thanks in advance!
Old Sep 15, 2016 | 11:19 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
I use the angled front side of the passenger footwell, just below the break where it goes vertical.
Old Sep 16, 2016 | 12:44 AM
mikem350's Avatar
mikem350
On the inner fenders works well. Keep away from exhaust for sure.
Doubt it will fit under the seat...
Old Sep 16, 2016 | 02:06 AM
USAFVeteran's Avatar
USAFVeteran
I'm running a 6AL in my 69. I put it between the headlights, in front of the radiator. I mounted it on a plate I made, and I used some rubber isolators. Not an issue in about 7 years now.
Old Sep 16, 2016 | 05:59 AM
fms93gt's Avatar
fms93gt
Thanks for the suggestion. I had not considered that area. Do you have any pictures of the bracket and the final installation?
Thanks again.
BTW- I am also a USAF veteran. I did jet engine overhaul on the GE J85 jet engine for the T38A Talon.
Thank you for your service.
Cheers!
Old Sep 16, 2016 | 05:48 PM
Crimson Thunder's Avatar
Crimson Thunder
i made a plate and installed mine on the windshield washer reservoir bracket.
Old Sep 16, 2016 | 07:14 PM
Shark Racer's Avatar
Shark Racer
This is where mine is, but mine is bolted directly to some metal up there. Nice and secret. The wires are run alongside the headlight vacuum lines. (78 MY)
Old Sep 17, 2016 | 01:12 AM
USAFVeteran
Don't mind the dust on the car, I have to pull the transmission back out, and the rest of the car is suffering for it
From the drivers side, obviously looking down
Straight down in front
Through center grill, up angle just a bit
From access hole under drivers side headlight, looking to the right side
Old Sep 17, 2016 | 01:59 AM
Kim72's Avatar
Kim72
Mounted mine up front, between the headlights, as well. Sealed all the joints on the box with clear silicone to keep any moisture out. Been good there for a number of years now with no issues.
Old Sep 17, 2016 | 05:35 AM
fms93gt's Avatar
fms93gt
Thank you so much for the pictures! This looks like the best location and with the engine and transmission out of my car it should be easier to install.
Thanks again for taking the time to add pictures!
Old Sep 17, 2016 | 07:48 AM
Lobzila's Avatar
Lobzila
On my 68, I put it behind the passenger side dash pad. No AC car, it had plenty of room and will not be exposed to the heat of the engine compartment. It not like you have to adjust it much once you set it up.
Old Sep 17, 2016 | 10:27 AM
USAFVeteran
It won't be hard to do, and the wires will be easy to route. Be sure to take in to consideration where everything will be when it all goes back together. That's why my small trans cooler has bent fins, I didn't do that. Missed it by that much(~~~~)
Old Sep 17, 2016 | 08:02 PM
mrvette's Avatar
mrvette
MEH, had one once, put it on two cars.....a Pontiac, and noted no difference in performance....
put it on my '72 vette, did better with a stock HEI.....don't waste your money....serious....
Old Sep 17, 2016 | 11:15 PM
cagotzmann's Avatar
cagotzmann
Thanks in advance!
No MSD 6A. I have a MSD 6530 Programmable unit.
This is my location.
To MSD 6A install location??
