timing 63 fuelie
Old Sep 16, 2016 | 12:26 PM
tfuith's Avatar
tfuith
Default timing 63 fuelie
hi guys i want to time my corvette but how do you move the distributor
it seems the oil line is in the way and will not let it turn. what is the secret thanks always for the help.
tom f.
Old Sep 16, 2016 | 12:53 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Touch base with the C2 folks. They can probably help.
Old Sep 17, 2016 | 11:36 PM
fuely's Avatar
fuely
tom f.
You loosen the clamp with a straight blade screwdriver and move it from there. The clamp is above the block area where non fuelies are located. In other words us the clamp instead of the bolt at the block.
Old Sep 18, 2016 | 11:54 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Not my picture, but here is one showing the band (clamp) you loosen
Old Sep 18, 2016 | 05:00 PM
terry82's Avatar
terry82
I have never seen one of those.
Old Sep 18, 2016 | 05:07 PM
0Willcox Corvette
Former Vendor
FI cars only Terry. The drive housing shown in the picture is for the fuel pump drive cable, on the other side is the tach drive cable. With the cables attached to the lower unit there is no way to adjust the distributor like conventional distributors, so they made the top portion of the distributor adjustable. Just think, you guys have one, maybe two or three cars to know, I've got to cover almost all of them..
-Willcox
Old Sep 18, 2016 | 05:49 PM
terry82's Avatar
terry82
-Willcox
Thanks for the info .Yes you see it all .but thats why we are lucky you guys help us out with your info and your videos,,,,Thank You .
Old Sep 18, 2016 | 06:48 PM
0Willcox Corvette
Former Vendor
My pleasure Terry! I've been on vacation the last two weeks so I've been a bit scarce but I'm home now.. I have some new video's coming soon too.
Old Sep 19, 2016 | 11:48 AM
gkull's Avatar
gkull
I had 64 FI injection on my 61 vette when I bought it and it did not have the nice band type cap shown by Willcox Corvette.
If you don't have enough rotation adjustment you can do several things. The easiest is to just move all your plug wires over one terminal to advance the timing and then you rotate the dizzy retarded to bring the correct timing in. The other choice is restabbing the Dizzy over one tooth.
Each dizzy post is 45 degrees (360/8) So it is a major change. don't fire the motor. You can then rotate the dizzy back one pole distance and your timing would be the same and be clear of the oil line interference.
Please don't post to go to the c-1 and c-2 forum. I maintain some of them for older people with too much money and they hire people to work on them.
Old Sep 27, 2016 | 10:37 PM
rogernison's Avatar
rogernison
Default Fuel i.e. Timing
tom f.
There is a clamp coller just below the distributor cap, loosen it to adjust. Timing. Just needs a flat blade screw driver. The upper part of the distributor including the cap moves, the distributor does not!
At the base of the fuelie distributor ther is a coller with a locating pin which keeps the distributor & intake manifold in alignment. The oil line is also another reason the lower portion of the distributor doesn't move.
That along with the tach drive cable & the fuel meter drive cable are additional reasons for the lower part of the distributor to remain stationary.
Good luck.
To timing 63 fuelie
