"winkie"
Old Sep 14, 2002 | 11:47 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default "winkie"
shut the car down without turning off the lights. turned off the lights and the left promptly closed, the right stayed up. I know VERY LITTLE about vacuum systems. should I leave well enough alone, since they work when the engine is on? if I tinker, where to start? what to look for?
Old Sep 15, 2002 | 01:07 AM
LT1driver's Avatar
LT1driver
Default Re: "winkie" (Markm10431)
I'd guess a vac leak in the headlight can. If works when eng on I would leave alone and just lower before shutting motor off. It can get expensive tracking down vac problems. It really is a personal call IMHO :cheers:
Old Sep 15, 2002 | 03:31 AM
Double Aught's Avatar
Double Aught
Better check out this thread first http://forums.corvetteforum.com/zerothread?id=387442
Old Sep 15, 2002 | 04:43 AM
BB wowbagger's Avatar
BB wowbagger
Default Re: "winkie" (sd pacecar)
I would check the relays..
I know my relays are bad,because when i start the engine the right light pops up without the lights on,but as the vac is building up it pops down again.. :cheers: :smash:
Old Sep 15, 2002 | 08:15 AM
Disco_Mike's Avatar
Disco_Mike
Default Re: "winkie" (BB wowbagger)
a "blinkie"? :lol:
Old Sep 15, 2002 | 08:29 AM
BB wowbagger
Default Re: "winkie" (Got79Fever)
yup,A blinkie.Not for long thou.Gonna tear it apart and check the seals this winter.. :smash: :smash: :cheers:
Old Sep 15, 2002 | 08:43 PM
Markm10431's Avatar
Markm10431
Parrothead
Default Re: "winkie" (LT1driver)
there is a can for each, right? I think that might be the problem. it's something to do when it either breaks or I have nothing better to fix
To "winkie"
