renegade manifold
Old Sep 26, 2016 | 08:26 AM
llabesab7's Avatar
llabesab7
Default renegade manifold
I may have the Renegade manifold installed om my 82 CE vette. Will that hurt the resale value if I decided to sell it one day?Thanks
Old Sep 26, 2016 | 08:33 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Did you keep the OE manifold, "just in case"? If you did, I'd say there's no loss in value.
Old Sep 26, 2016 | 09:22 AM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
You should easily be able to tell if you have a Renegade on your motor or not. It says RENEGADE across the top plate in big letters. Pull your air cleaner and have a look.
If you are a purist, then remove it if installed. Otherwise you should be good to go.
Old Sep 26, 2016 | 09:27 AM
mrvette's Avatar
mrvette
I have a LT1 FI manifold on my '72, and retained the HEI in back up top, the way GOD intended......
see sites below for a few pix.....
Old Sep 27, 2016 | 06:03 PM
llabesab7's Avatar
llabesab7
Do you know anyone that has experienced the Renegade manifold?
Old Sep 27, 2016 | 10:00 PM
cv67's Avatar
cv67
St. Jude Donor '05
No why would it?
Old Sep 27, 2016 | 10:22 PM
llabesab7's Avatar
llabesab7
No why would it?
you tell me
Old Sep 28, 2016 | 05:22 AM
fishslayer143's Avatar
fishslayer143
Yes...I have a friend with the # 6th Renegade ever made.. It will allow the engine to breath.. Maker claims 20-30 HP improvement.. no issues.....Works better with better cam and heads
Old Sep 28, 2016 | 07:42 AM
llabesab7's Avatar
llabesab7
thankyou
Old Sep 28, 2016 | 04:05 PM
Buccaneer's Avatar
Buccaneer
This is a true statement, the average is 30 RWHP, but we have seen more as well. Good luck and do a before and after if you can. That is the only way to see what you really got from the swap. 383 and bigger cube motors really love the manifold.
To renegade manifold
