Low Fuel Light
Old Oct 2, 2016 | 07:00 PM
news2me's Avatar
news2me
Default Low Fuel Light
My Low Fuel Light, is Intermitting going on and off. My fuel gauge is working so, I don't think its the float. Does anyone know if there a sensor inline somewhere...
Old Oct 2, 2016 | 07:06 PM
'75's Avatar
'75
It works of the same sending unit as the gauge.
Old Oct 2, 2016 | 07:18 PM
news2me's Avatar
news2me
[QUOTE='75;1593174314]It works of the same sending unit as the gauge.[/Q
Then why would the gauge work just fine and the Low Fuel Light, go on and off, intermittent..
Old Oct 2, 2016 | 08:30 PM
'75's Avatar
'75
My best guess is that the low fuel light module has a problem. New ones are available from Willcox.
Old Oct 2, 2016 | 10:00 PM
terry82's Avatar
terry82
does it matter how much fuel is in the tank?when the tank has low fuel, it will slosh a round a lot .The float maybe just moving that much .
Old Oct 2, 2016 | 10:32 PM
cagotzmann's Avatar
cagotzmann
The low fuel sending circuit is not sensitive to quick voltage changes (float moving around quickly). It has capacitor circuits to prevent this. But all the same if it flickers then there is still a problem in the module. Replace all the capacitors on the circuit with the same rating and re-test or just purchase another module.
Old Oct 2, 2016 | 10:47 PM
news2me's Avatar
news2me
[QUOTE=terry82;1593175331]does it matter how much fuel is in the tank?when the tank has low fuel, it will slosh a round a lot .The float maybe just moving that much .
The gauge is working. The low fuel Light is turning on and off, as I
drive. It doesn't matter, if I have a full tank or 1/2 tank. Its not slosh, if I'm idling in front of the house, it still goes on and off.
Old Oct 3, 2016 | 06:03 AM
news2me's Avatar
news2me
It doesn't flicker, it will be on for a few minutes. then go off and then come back on a gone. Two minutes later off again...
Old Oct 3, 2016 | 01:53 PM
Antz81's Avatar
Antz81
Sounds like a bad module or poor connections.
Old Oct 3, 2016 | 09:31 PM
terry82's Avatar
terry82
i would start with checking ground wires.I just checked my low fuel light the other day.did not mean too but was on the highway not close to a gas station.my low level light came on with 4 gallons in the tank.
Old Oct 5, 2016 | 07:11 AM
Street Rat's Avatar
Street Rat
The last time my low fuel light was on I was already out of gas. Don't put much faith in it's accuracy.
Old Oct 5, 2016 | 01:46 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
[QUOTE=news2me;1593175606]
It is the transistorized board failing.
Serious, just get a new one. You can take out your glove box and do a reach around for installation. 10 minutes max and 8 of those are routing around for another beer.
Old Oct 5, 2016 | 09:00 PM
news2me's Avatar
news2me
[QUOTE=billschroeder5842;1593192378]
The glove box???, 77's don't have a glove box. Are you talking about the map pockets, panel...
Old Oct 6, 2016 | 10:18 AM
billschroeder5842
[QUOTE=news2me;1593195203]
Duh, my bad. Yes, map pocket.
(Doesn't everyone have an '82???)
Old Oct 6, 2016 | 09:08 PM
news2me's Avatar
news2me
I'm going to order it from Willcox, this weekend... So I remove the dash panel and I'll be able to reach it... How do I remove it, does it just snap out, are there wires going to it...
Old Oct 6, 2016 | 09:27 PM
'75's Avatar
'75
The module should just twist a quarter turn to the left and come right out.
Old Oct 6, 2016 | 09:37 PM
news2me's Avatar
news2me
So just grab it give it slight turn to the left, there are no wires??
To Low Fuel Light
Old Oct 6, 2016 | 09:47 PM
'75's Avatar
'75
No wires, it twists into a bulb like socket, in fact some have mistakenly put one of the plastic bulb sockets in place of the module, but it doesn't work right, the bulb stays on. The low fuel light is plugged into the module and the module is twisted into the back of the gauge cluster.
Old Oct 7, 2016 | 09:15 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The module works off the ohm input to the fuel gauge so if the gauge is still working fine then your issue would probably be the module. It could be a flex circuit the module mounts into as well, there are three fingers off the module that touch the flex board and possibly one could be bent, corroded or you flex circuit board could be defective..
The module has a built in delay to it so that when you turn are a little low on fuel and you turn a hard corner the lamp won't flicker off and on.
StreetRat makes a good point too... some of the old GM modules wouldn't come on until it was too late... On our module, we raised the limit to avoid this issue so that when the needle is right inside the red area the lamp should come on.
Willcox
Old Oct 7, 2016 | 09:33 PM
news2me's Avatar
news2me
Willcox
Yep, my gauge works just fine. Like I said earlier, I'll be driving along and the light will come on. It will stay lit, for a minute or two. Then it will go off and a few minutes later, its back on again..
I'm going to order one from your guy this weekend..
