Headers for ZZ4
Old Oct 7, 2016 | 08:53 AM
PRIrish's Avatar
PRIrish
Default Headers for ZZ4
I'm think about putting headers on my 76 with a ZZ4 crate engine. Summit Racing recommends a Sanderson Blockhugger CC1DP-SEC which is ceramic coated and for engines with D shaped ports. Any suggestions or comments?
Old Oct 7, 2016 | 04:53 PM
theandies's Avatar
theandies
I'm running Headman D-Ports. Can't remember where I got them. They are the block hugger design. I had them JetHot coated a while back. I'll dig up some pictures if you want.
Old Oct 7, 2016 | 11:01 PM
cagotzmann's Avatar
cagotzmann
zz383 fast burn heads d-port
Mine are cc134dp which are 1-3/4" tube for dport
https://www.summitracing.com/int/parts/snh-cc134dp
They fit very tight on the driver side against the steering box
I had to dent a tube to fit
The 1-5/8 would have fit better.
Old Oct 8, 2016 | 08:35 AM
PRIrish's Avatar
PRIrish
The Sanderson headers are a shorty and blockhugger type, and I checked with Sanderson who related they would work with my 76 with no clearance problems. I appreciate the offer for pictures, but I don't think that is necessary as I've decided to buy the Sanderson headers. Thank you for your response, and offer of pictures.
Old Oct 8, 2016 | 08:39 AM
PRIrish's Avatar
PRIrish
Thanks for responding. I've decided to go with the Sanderson headers after Sanderson informed they would work with my 76 with no clearance problems. Also, the CC1DP-SEC have 1 5/8 tubes so I should not encounter the steering box problem you encountered.
To Headers for ZZ4
