New distributor, rev counter dont work.
Old Oct 14, 2016 | 02:59 PM
clwi's Avatar
clwi
Default New distributor, rev counter dont work.
Bought a new distributor, MSD pro billet for my BB.
Thing is, my rev counter does not work, is there another size of wire to match the dist?
Old Oct 14, 2016 | 03:33 PM
theandies's Avatar
theandies
What year?
By the looks of your avatar you have an early C3. I don't know about BB's but early C3's with SB's the tach is driven off the distributor via a speedometer type cable. It is purely mechanical not electrical. MSD does make a tach drive distributor because I'm running one.
Also, if you do have an MSD tach drive distributor it should have come with a little brass insert to drive the cable. If that is not installed your tach will not work.
Old Oct 14, 2016 | 03:50 PM
clwi's Avatar
clwi
Originally Posted by theandies
What year?
Mine is a 72 with tach drive, i dont have an insert so that is probably wy it does not work. Stock wire now, will get an insert. Thanks!
Old Oct 14, 2016 | 03:53 PM
theandies's Avatar
theandies
The insert should have come with the distributor. And that is not a wire it's a drive cable. Be careful not to pull it out as it will disengage on the other side in the tach (rev counter) and it's a pain in the *** to get it back it.
It should look like this:
Old Oct 14, 2016 | 03:54 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I don't know about BB's but early C3's with SB's the tach is driven off the distributor...
FWIW, so did the big blocks.
Old Oct 14, 2016 | 03:57 PM
theandies's Avatar
theandies
That's what I figured but I didn't want to say it did when I don't know.
To New distributor, rev counter dont work.
