Interior Dye ?????
Old Sep 16, 2002 | 06:41 PM
MrBigButt98Conv's Avatar
MrBigButt98Conv
Default Interior Dye ?????
Hi There
I am getting ready to Dye my 74's Interior. I am spraying over the old trim. This being the case, do I need to Prime it first? I just finished taking all of it out of the car & scrubing it clean.
To prime or Not to prime ?????
Old Sep 16, 2002 | 06:50 PM
vettfixr's Avatar
vettfixr
Default Re: Interior Dye ????? (MrBigButt98Conv)
You don't have to prime it. I cleaned mine with a rag damp with lacquer thinner to remove all the oils and grease. Once that's done spray the dye in thin coats. If you try to use thick coats it will obscure the grain pattern and not dry properly. Spray a thin coat and then wait 10 minutes before you do the next. Good luck.
Old Sep 16, 2002 | 07:01 PM
Paul L's Avatar
Paul L
Default Re: Interior Dye ????? (vettfixr)
I agree. It can be done without the primer. Here is a recent project of mine.
http://forums.corvetteforum.com/zero...986732#3986732
Old Sep 16, 2002 | 07:20 PM
Pedro'74's Avatar
Pedro'74
Default Re: Interior Dye ????? (paul79)
Yeah, what they said! :D
Lemme just add a couple of notes:
-Simple Green works great for cleaning the parts.
-If the paint/dye runs, carefully wipe it immediately with a tissue, and spray another coat. It won't be noticeable.
-Avoid doing it on humid days.
-Pedro
Old Sep 16, 2002 | 07:24 PM
verskel's Avatar
verskel
....yep - that's the way to go !!! :cheers:
Old Sep 16, 2002 | 07:41 PM
82dukman's Avatar
82dukman
Default Re: Interior Dye ????? (verskel)
I'm with them. I redid the interior of my CE. Just cleaned the parts off with laquer thinner and sprayed them three times very lightly. Looks like brand new now
Old Sep 16, 2002 | 08:23 PM
MrBigButt98Conv
Default Re: Interior Dye ????? (Pedro'74)
Thanks for your suggestions, Let me ask you, once I use the dye, should I spray it with a sealer or anything, & would one can do all of the trim parts, I am buying new door panels , so I would not need it for anything other than the trim..
THANKS SO MUCH
Old Sep 16, 2002 | 08:25 PM
MrBigButt98Conv
=Thanks for your input, how far will a can go?
Old Sep 16, 2002 | 08:30 PM
vettfixr's Avatar
vettfixr
I think I used 2 or 3 cans for all the trim and the dash. I didn't do my seats or door panels but I did everything else including the backs of the seats.
82dukman's Avatar
82dukman
I used a quart and my air compressor with a spray gun. I did the seat bottoms, backs and T-top halo three times on all pieces. I didn't use a sealer afterward and I can't see any wear.
To Interior Dye ?????
