396 Dyno Numbers....
Old Oct 25, 2016 | 05:00 PM
StraubTech's Avatar
StraubTech
Default 396 Dyno Numbers....
Many of you have the 288/300 cam in builds. Here is a dyno test of the camshaft in a 10 to 1 396 with a set of 702 GM castings. Cam is the Ol'School 600/570 229/241 on a 109 that many of you have. What surprises me is the torque it has:
Old Oct 26, 2016 | 11:38 AM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Did you draw that torque trace with a straightedge?
It doesn't get much flatter than that!
Old Oct 26, 2016 | 11:53 AM
StraubTech's Avatar
StraubTech
Kudo's goes to the builder and the customer. This turned out to be a nice combo. It does have an Eddy Air gap intake and a Sean Murphy Holley 750.
Old Oct 26, 2016 | 12:37 PM
jim-81's Avatar
jim-81
that's what I thought. Holy cow
Old Oct 26, 2016 | 12:40 PM
StraubTech's Avatar
StraubTech
Those with larger engines on here with the same camshaft can expect the torque band to be similar just in a lower rpm range.
Old Oct 27, 2016 | 04:36 PM
StraubTech's Avatar
StraubTech
Some have contacted me about what was done to the head and what was on it for exhaust....from the customer........1 7/8 STOCK CAR HEADER, SO WITH A REGULAR 1 7/8 HEADER, TORQUE AND HP WOULD PROBALLY BE A LITTLE BETTER,HEADS ARE 702 ,MILLED TO 96 CC WITH A 0.0028 THOUSATHS COMETIC GASKET(MLS)WITH A QUENCH @0.0040.STOCK VALVE SIZE ,FERREA VALVES ,HARDENED SEALS ON EXHAUST, NO PORTING.10.1 CR.
Old Oct 28, 2016 | 02:35 PM
clwi's Avatar
clwi
Chris!
Nice numbers, as you know i got this in my 468.
Have not dynoed it, but my engine guru calculated it to 500+ TQ, but only 400 +Hp....
Do have LT:s and full exhaust..
Stock 049 heads and intake on my 72 Vette.
Whatever nr:s, it runs great!!
Old Nov 1, 2016 | 11:19 AM
StraubTech's Avatar
StraubTech
Originally Posted by clwi
Chris!
Well now you can show your engine guy this dyno sheet as you have proof that it is a pretty good bet you have more than 400HP.
Old Nov 1, 2016 | 12:22 PM
ddawson's Avatar
ddawson
clwi, at the wheels he would be correct.
This is my dyno tune session. Numbers should be higher on a dynojet.
496, Edelbrock heads, Straub roller, LS6 intake.
To 396 Dyno Numbers....
