Vacuum leak??
Suggestions? Should I get a new hose and run straight without the plug? I'm a novice and know next to nothing about carburetors, so any help/suggestions/explanations would be greatly appreciated!!
But while operating, I detached the brake booster hose which had lots of vacuum. I detached the hose I've been dealing with from the EGR and plugged it with my finger and didn't really see any change in idle.
Any ideas why the idle only seems to really drop at operating temp? Oh, btw, I almost always hear a ping when I start the car. Usually only at start up. Not sure if it's related. But I checked the diaphram on the EGR valve which seems to be fine. I thought maybe it was stuck open.
I don't know what to do next. Any suggestions??
Our cars have so many vacuum operated components that they can suffer the death of a thousand tiny cuts. The ends of the vacuum hoses stretch over time and all or nearly all of them can be leaking just a little. Together all of those little leaks become a big leak
Also check the four bolts that secure the carb to the intake manifold are properly torqued. The gasket can compress over time resulting in a leak there.
The headlights, climate control, cruise control (if you have it), fuel EVAP system, vacuum advance, transmission modulator (automatics) and brake booster are all vacuum operated and potential sources of leaks.
Many hoses can be trimming a 1/2" or so at each end but others to not have sufficient slack. Dr. Rebuild (look it up) offers excellent quality vacuum hose replacement kits with great diagrams.
Replacing all of the vacuum hoses in my '79 L82 was the best thing I've done to the car performance wise! Combined with the previous regular tune-up things (plugs, wires, rotor, etc.) and generous use of carb/choke cleaner mine now starts, idles and runs like new.
From your experience, does this "sound" like something that might be a vacuum leak? I know there are many things that could be the issue, but everything seems to be working properly. Also, from my picture, would me removing that bubba bolt and running the EGR directly to the carb cause any problems since the TVS valve is not there?
Thanks so much for the help guys!
While mine never had much problem with stalling at idle it would happen on occasion when warm. The idle speed adjustment was so far advanced however that it was beyond the position for the solenoid "bumps up" the idle speed with the A/C running. The first vacuum hoses I replaced were all of those involved with the headlamps. The idle speed went up noticeably and I had to adjust it down. I replaced all* of the remaining hoses at once and the idle speed went WAY up.
*My HVAC system was leak free so I didn't replace those hoses. I also neglected to replace the little 1" or so vacuum line at the transmission modulator valve and it failed during my first shake-down cruise with the "new" car! Fortunately it failed less than a mile from home so I was able to limp back in first gear.
I had previously tested many of the hoses themselves for vacuum leaks and found none. The problem was that the ends of all of them were stretched out. During the big replacement though I found that the EVAP system vapor hoses were utterly toast. While the vacuum control hose for the EVAP system didn't seem any worse that the rest of the hoses the system was obviously not functioning. Since the EVAP system is connected to the PCV system I believe it was preventing the PCV from working properly as well.
You can check the leaks best by plugging each hose source at the engine, thereby taking the hoses out of service one at a time and see if anything changes.
A vacuum gage is a great tool to have for this work.
Good luck!
Good luck!
I just ordered a vacuum gauge so I'll start there and also I think I'll try to get the mixture correct. The smell is so horrible when I run it in my garage. I hope I can get it running a little less harsh as far as smell.
BTW, the rubber plug on the front of the carb was toast. That was probably a little leak there as well. I'm getting there, slowly.
Thanks for your help as always everybody! If anybody can pinpoint that Bubba bolt in my second picture, I'd appreciate it!
Good luck!
Good luck!
Thanks again. I'll update this week.
