Steering column/ignition switch diagram needed!!!
Old Nov 1, 2016 | 07:52 PM
Charlie80vette's Avatar
Charlie80vette
3rd Gear
Default Steering column/ignition switch diagram needed!!!
I need a diagram/schematic and instructions on how to replace the parts in the steering column and ignition switch on my 1980 corvette L82.
A mechanic drilled out the old ignition (wrong) and then took apart the steering wheel to fix the problem and now he can't put it back together.
Any videos on the TILT steering wheel only. I see a lot of info on the Telescopic and Tilt columns but not much on the Tilt only.
Thanks for the help
Old Nov 3, 2016 | 02:33 AM
Gale Banks 80''s Avatar
Gale Banks 80'
There is no such thing as a 1980 Column that is not Tilt Telescopic.
Old Nov 3, 2016 | 07:12 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Yep. If you have tilt you also have telescopic. That or the steering column has been replaced.
To Steering column/ignition switch diagram needed!!!
