81 differential
Old Nov 2, 2016 | 08:56 PM
silvvette's Avatar
silvvette
Default 81 differential
is it possible to remove the differential housing unit from the 81 while leaving the batwing(bolted to the frame) and spring(bolted to the batwing and both trialling arms) in position?
Old Nov 3, 2016 | 01:17 AM
Gale Banks 80''s Avatar
Gale Banks 80'
Yes, but Your going to hate Your self by saving the time to undo 4 Bolts.
Old Nov 3, 2016 | 12:36 PM
silvvette's Avatar
silvvette
true, but would it avoid having to get a wheel alignment?
Old Nov 4, 2016 | 03:38 AM
Gale Banks 80'
If that's what You are after then I would probably pull the whole thing out. Pull the Trailing Arm Bolts and the Batwing Bolts. Then drop and slide backwards, the Yoke in the Trans will pull out so You will not need to disconnect the U-Joint Bolts which are time consuming.
Old Nov 4, 2016 | 02:27 PM
fishslayer143's Avatar
fishslayer143
Drop the Batwing... you will save a lot of time and skin
Old Nov 4, 2016 | 06:33 PM
larryg3's Avatar
larryg3
I would have to agree with fishlayer 143! not worth the headache!!! top the batwing
Old Nov 5, 2016 | 12:09 PM
silvvette's Avatar
silvvette
thanks eveyone for the feedback. going to start with that and line scribe the location of the bolts and take pictures along the way.
To 81 differential
