Exhaust drone
Old Nov 3, 2016 | 10:01 AM
sakins.02vert's Avatar
sakins.02vert
Default Exhaust drone
I have a 72 350 with Hooker competition headers and side pipes.. It looks like the PO had put some insulation underneath the car between the headers and front floor.. I have a lot of drone inside the cabin.. I think its worse when the tops are on and windows are closed.
What would you say is the best way for me to minimize the drone?
Thoughts:
1. Drill holes/Insulate side pipe inserts more (I have 2 1/4 sweet thunder inserts)
2. Use dynamat or something similar inside cabin under carpet in front and rear compartment.
3. ?
Any suggestions from someone who has been down this road already?
Old Nov 3, 2016 | 10:39 AM
TKO Performance's Avatar
TKO Performance
Premium Supporting Vendor
Active Streak: 90 Days
From: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
Thoughts:
3. ?
Interior drone is caused by vibration/frequencies. Eliminating drone is tough. However you can sufficiently reduce it. A good way to address it is by damping the under surface. There is dynamat and other butyl rubber type products you can use BUT before you permanently stick those down, you might want to consider DeadMat.
Its lighter then dynamat (a little cheaper too) but its weight to performance ratio is amazing. Does a great job at crushing vibration.
Here's a link to check out it if your interested. There's a 20sqft and a 36 sq ft kit. http://store.tkoperformance.com/1997200412.html
There is also a quick video provided to show you what a 5 inch piece does. Good luck.
Old Nov 3, 2016 | 03:07 PM
REELAV8R's Avatar
REELAV8R
Idea #1 sounds like it's worth a shot. Drone is from a certain resonance frequency. If you can change that frequency then it will not be so irritating to you. Insulating the insert and or drilling holes should change that frequency. Without know how it will change it will be a method of trial and error though. Different inserts may be the only solution if idea #1 doesn't work.
I'm guessing your drone is occuring in the 1800 to 2200 RPM range or so?
I like those dead mats too but the drone will still be there from the pipes. May end up being a combo of the two. Drone is also subjective. Drone to one person is just a rumble to another. So you'll have to be the judge.
Old Nov 3, 2016 | 04:39 PM
MelWff's Avatar
MelWff
I find it strange you have a drone with side pipes, typically the noise would overpower any drone. Which muffler inserts are in the side pipes?
Old Nov 3, 2016 | 07:49 PM
flyeri's Avatar
flyeri
I think your hearing the exhaust. Sweet thunders are loud. Hooker glass packs are pretty quite at cruise. They are restrictive under WOT but if you like cruising they are pretty good.
Old Nov 4, 2016 | 08:58 AM
sakins.02vert
Thanks guys.. Yes they are 2 1/4/ inch sweet thunder inserts.. It seems to be louder with the tops on and windows closed.. almost giving me a headache.. i was thinking its drone.. but maybe its just loud and echoing inside the cabin?
I think my #1 option should be inexpensive.. and with a combination of that and some kind of dead mat or dynamat inside the cabin I'm thinking that *should* help.. My carpet is not so nice so might not be a bad idea to replace it anyway.
Any other suggestions? other than changing the exhaust.. ?
Should I be doing something underneath the car? With padding/sound material?
Old Nov 4, 2016 | 10:37 AM
REELAV8R's Avatar
REELAV8R
I put sound deadening material inside the door. Took the door panel off, took off the plastic and stuck it directly to the inside of the outer panel of the door. It's basically a big fiberglass drum for sound. Helped a lot with my sidepipes.
Old Nov 4, 2016 | 12:14 PM
sakins.02vert
makes sense.. what sound deadening material did you use?
Old Nov 4, 2016 | 12:28 PM
REELAV8R's Avatar
REELAV8R
A product called Fat-mat Mega-mat. Very similar to Dynamat extreme. It's a butyl rubber with foil on it. Peel and stick. There is lots of room inside the door though so a guy could put something much thicker in there.
I may go back in and apply something even thicker to get more sound deadening. Pipes louder now since I upped my CR to 10.6:1.
Old Nov 4, 2016 | 03:02 PM
NewbVetteGuy's Avatar
NewbVetteGuy
Is there such a thing as H pipes or X pipes with side pipes? -I know they can cancel out and dramatically reduce exhaust drone for normal dual exhaust; just not sure if they're feasible with such huge distances (relatively) between the two tubes with side pipes.
Adam
Old Nov 4, 2016 | 05:01 PM
MelWff's Avatar
MelWff
I think your choices are going to the 1 3/4" inserts or try the Hooker or Dougs reverse flow insert which will kill top end power but be quiet.
Old Nov 5, 2016 | 08:55 AM
sakins.02vert
Thanks Guys. I'll start by pulling the inserts, drilling hole sin them and wrapping with insulation and steel wool.. Then I'll take off the door panels and insulate in there.. See how that helps.. I may even buy a DB level tester so I can see if it really helps.
Old Nov 5, 2016 | 10:38 PM
REELAV8R's Avatar
REELAV8R
Not sure about the steel wool idea. If it's corse enough I guess it'll work. Fine steel wool is flammable.
Old Nov 5, 2016 | 10:47 PM
REELAV8R's Avatar
REELAV8R
Standard fiberglass will just get pounded into dust and exit the pipe in a relatively short period of time.
In my dirt bike muffler packing days I used a stranded fiberglass material that lasted significantly longer. Like this pink stuff.
http://www.motorcycle-superstore.com...FQgMaQod71cOUw
It also comes in a mat made for four stroke bikes, I used either the mat stuff cost more.
Just an idea of what might be available. There may be an automotive specific packing application that will work better.
Old Nov 6, 2016 | 01:09 AM
slickfx3's Avatar
slickfx3
Default helmholtz
https://www.google.com/search?q=helm...qtDF0Q_AUICCgD
To Exhaust drone
