C3 cold engine start problem
Nov 5, 2016 | 09:26 PM
3rd Gear
Hi I am new.
I bought Corvette C3 1977 in Florida and imported to Poland.
Everything works great but I have one problem to be solved.
When I try to start cold engine after depressing gas pedal 4-6 times before the operation, engine fires up for several seconds and then dies.
It seems that engine can not operate on slow turns. When I try to add gas when engine operates to warm it up it dies momentally.
I have to repeat the operation 6-9 times (each time engine fires up and dies) than after 9-10 tries engine is operating on slow turns.
When engine is warm it fires up and operates on slow turns at the first time.
Battery is a brand new, plugs are new, high voltage wires are new.
It could be a problem of the fuel pump or carburetor.
I do not want to change to many things that is why I looking for giving me a hand in this case.
Nov 5, 2016 | 09:45 PM
From reading the description, it sure sounds carburetor choke related to me.
What kind of carb do you have?
Does it have a Choke and is the choke working?
I would experiment adjusting the choke and fast idle screw to see of that helps.
John
Nov 5, 2016 | 10:02 PM
3rd Gear
Quote:
Originally Posted by
johnt365
John
John thank you for your tip.
I am not good at it I will take a picture and post it here tomorrow.
Regards
Andy
Nov 6, 2016 | 11:47 AM
2016 C3 of Year Finalist
Sounds like the choke to me also. Post picks with the air cleaner off , both left and right sides of the carburetor please. Thanks
Nov 6, 2016 | 03:28 PM
You should only need to depress the accelerator once to set the choke. You are probably flooding the engine with 4-6 kicks at the gas pedal.
Nov 6, 2016 | 05:45 PM
3rd Gear
Ok I plan to take pics tomorrow afternoon my time (European time) I will post them. Thank you for your help. I really appreciate it.
Andy
Nov 6, 2016 | 06:43 PM
paul 74
Nov 7, 2016 | 08:51 PM
Nov 8, 2016 | 11:31 AM
Corvette of the Year Winner 2017
and once that overdose (4-6 pumps) of gas is burned, it dies due to choke not working,
which would keep the fuel mixture rich until warmup.
Check the choke operation thoughly, your 4-6 pumps is a bandaid for the real problem.
