Convertible top tack strip installation question
Old Sep 17, 2002 | 02:05 PM
R1234's Avatar
R1234
Default Convertible top tack strip installation question
I ordered a new top along with new tack strips. The tack strips are plastic and will not fit down into the frame channels because they are to wide. Is this normal? Do they have to be trimmed? :confused:
Old Sep 17, 2002 | 03:49 PM
Steve Adkins's Avatar
Steve Adkins
Default Re: Convertible top tack strip installation question (68rdstr)
I can't help you any, but will be following close because I am getting ready to do this same thing as soon as my parts get here.
Old Sep 17, 2002 | 04:49 PM
gkvetteuno's Avatar
gkvetteuno
Veteran: National Guard
Having seen the plastic type , I could not see how the rear strip would fit well in the channel. So I chose to buy the original fiber type from Ecklers. It fit properly and worked great. Ecklers goes on to say the rubber strips won't hold tacks.
Old Sep 17, 2002 | 05:49 PM
GTR1999's Avatar
GTR1999
Default Re: Convertible top tack strip installation question (gkvetteuno)
What size tac's are supposed to be used? 1/4" x 3/8"??
gary
Old Sep 17, 2002 | 05:53 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: Convertible top tack strip installation question (gtr1999)
You can force the plastic/rubber tack strips into the channels. You might have to do some trimming, but you want them tight. In some places, I used double thicknesses of the tack strip. Where I used a double thickness, I glued, and then stapled the strips on top of eachother. Chuck
Old Sep 17, 2002 | 06:09 PM
Wrencher's Avatar
Wrencher
Default Re: Convertible top tack strip installation question (Chuck Gongloff)
I used the hard rubber strips and used a pair of those body type flat Vise-Grips to press them into the grooves. It took awhile, but they fit VERY tight and worked great. I did spend a while cleaning out the groves and used 3M adhesive in the groove (very little) for insurance. My front header was rusted a bit, and the tabs that hold the front tack strip were gone. I had to rivet it, but will replace the header and re-do the front.
Hans
Old Sep 17, 2002 | 06:15 PM
gkvetteuno's Avatar
gkvetteuno
Actually there is not much need for tacks, maybe in the rear strip. most of the installation is done with staples, 3/8 in most areas except the front 1/4 and 3/8 there. Stainless steel staples are a good idea.
Old Sep 17, 2002 | 11:38 PM
GTR1999's Avatar
GTR1999
Thanks for the correction, I meant Staples instead of Tacks. I just picked up a pneumatic stapler from Harbor freight for $25 it should work good for this job. I have to find out who sells the ss staples though.
Gary
Old Sep 18, 2002 | 02:14 AM
R1234's Avatar
R1234
Thanks guys for all the replies. Sorry I couldn't get back sooner but I'm working the swing shift. I shoulda known it wasn't going to be easy.
I have located a local guy that has experience with convertible tops. He even makes house calls.
Old Sep 18, 2002 | 02:07 PM
Wrencher's Avatar
Wrencher
Sounds like a plan...
Old Sep 18, 2002 | 02:28 PM
Alwyn678's Avatar
Alwyn678
How much...........?? Guy is charging me 300 bucks :eek:
Old Sep 19, 2002 | 02:19 AM
R1234's Avatar
R1234
Default Re: Convertible top tack strip installation question (Alwyn678)
I haven't talked to him yet. I just got his telephone number from a friend.
I'll post it when I find out.
Old Sep 19, 2002 | 11:11 AM
R1234's Avatar
R1234
Alwyn678,
I talked to the guy this morning about coming over and doing the top install. I put on the tack strips, furnish the air compressor and he'll bring all the other tools/supplies needed. Price $150.00. The fellow that I gaveme his number says he does good work and has done his 66, his sons 65 another 68. After my new weatherstripping arrives and I get the tack strips installed I'll give him a call and set up a time.
Old Sep 19, 2002 | 11:15 AM
Alwyn678's Avatar
Alwyn678
Alwyn678,
Wow that is cheap Half of what this guy wants.......where did you get your weather stripping
Old Sep 19, 2002 | 11:25 AM
R1234's Avatar
R1234
The Last Detail. Also, That's a beautiful paint job!
[Modified by 68rdstr, 9:29 AM 9/19/2002]
Old Sep 19, 2002 | 12:21 PM
Alwyn678's Avatar
Alwyn678
Cool that is my backyard......Thanks for the Compliment :cheers:
To Convertible top tack strip installation question
