It's coming after me!
Old Sep 18, 2002 | 01:46 AM
KENS78SILVERANNIV's Avatar
KENS78SILVERANNIV
Default It's coming after me!
Hot air is getting into the interior...(under pressure) from the air ducts. I've disconnected the heater fan under the hood. Is there another fan somewhere delivering air into the car? I can divert it to the vents and defroster to get it off my feet... but, where is this coming from? :( And how do I turn it off?
Old Sep 18, 2002 | 02:03 AM
kingdavidrules's Avatar
kingdavidrules
Default Re: It's coming after me! (KENS78SILVERANNIV)
infamous c3 hot foot :lol: take your glove box lining out and make sure the heater door is closed all the way, it may need to be adjusted. i stll have that problem but dont mind as the winter is coming.
Old Sep 18, 2002 | 08:35 AM
rrent's Avatar
rrent
KENS78SILVERANNIV - a short term "fix" until you get to taking your passenger side dash out is to disconnect the heater hoses - no hot water to the heater core should mean no heated air to your vents. Of course on those 100+ degree days ( like we get here in Texas) any air coming in is still going to be less than cool.
good luck
Old Sep 19, 2002 | 01:34 AM
KENS78SILVERANNIV
Default Re: It's coming after me! (rrent)
I've already installed a valve to shut off the hot water to the heater core... but hot air is still being "pushed" somehow in through the ducts. I will have to check the heater door to make sure it is shut. Don't need any hot air on these 95 degree California days! :crazy:
Old Sep 19, 2002 | 03:33 AM
Jvette73's Avatar
Jvette73
As the engine compartment gets hot and all the surrounding firewall and what not does too. I think its normal for air to be pushed thru from pressure when the car is in motion. Pressure built up in the cowl area will force the air thru. If you can block the intake for the entire duct system then maybe you can reduce some of the heat getting in.
To It's coming after me!
