timing chain
Old Nov 19, 2016 | 12:48 PM
martys76's Avatar
martys76
Default timing chain
is a double roller timing chain really necessary to a standard timing chain 350 small block not high horse power
just changing out cam to something a little better summit 1103 cam shaft
Old Nov 19, 2016 | 06:02 PM
'75's Avatar
'75
A replacement chain and gear set from the local parts store is just fine, will probably run 100,000 miles easy. Or you can spend lots of money to get the most expensive one and it wont run a bit longer or better.
Old Nov 19, 2016 | 07:41 PM
sunflower 1972's Avatar
sunflower 1972
I know SINGLE roller timing chains are available if you want the added strength.
To timing chain
