Trying to identify a wire
I tried to go tidy up under the hood before it starts to rain and found this clipped wire. The clipped end was near the headlights/horn, I just pulled it in to get it all in the pic. Looks like it was clipped years ago considering the corrosion.
I can't ID it just from looking at a Wilcox schematic.
Now the only electrical thing that I know does not work is the horn so that's the likely suspect.
Received 1,294 Likes
Yes, has power all the time. If you have no light housing simply disconnect it from the black connector. Keep this pigtail as the white plastic capsule is the fuse link.
Yes, constant power, uses a mercury switch to turn it on when the hood opens.
http://www.zip-corvette.com/77-82-un...sing-only.html
http://www.zip-corvette.com/77-96-un...ry-switch.html
http://www.zip-corvette.com/77-80-ho...ound-wire.html
I'm just curious, this car will never be a resto type project
shok (11-20-2016)
