steering system disassembly
Old Sep 18, 2002 | 11:22 AM
Lohkay's Avatar
Lohkay
Default steering system disassembly
Well...its the first time I dissassemble something like that and I don't know how to do it...for exemple, I remove the cutter pin from the tie rod to spindle nut, removed the nut... I was sure it was going to fall out or worst case it would easily go through with a few taps with the hammer... But no... after some pretty heavy blows, its still there. Did I miss something? I mean...its a bolt going through a hole no? And there shouldn't be any rust as that part rotates when you turn....so whats the catch? I tried the same for a few other nuts on the system and I get the same problem... HELP ME! :lol:
Old Sep 18, 2002 | 11:30 AM
Bobchad's Avatar
Bobchad
Default Re: steering system disassembly (Lohkay)
A lot of the steering components require a pickle fork, a wedge shaped tool that has a split in the middle. You put the bolt in the split, hammer on the end and the wedge forces the bolt out. I would not hammer on the steering components.
Old Sep 18, 2002 | 11:35 AM
Fevre's Avatar
Fevre
Default Re: steering system disassembly (Bobchad)
What he said. I picked up 2 diff size forks just to have, less than $10 a piece at the local parts store if I remember right.
Old Sep 18, 2002 | 11:48 AM
vettesite's Avatar
vettesite
Don't start hammering anything until the you have the spring compressed and it chained to the control arm. I'm sure you do but I wouldn't want you to get hurt, even killed by a flying spring.
You need a ball joint separator (pickle fork) and a 3lb dead blow hammer (cool name :) ). I could not bust mine loose with a regular hammer. It's not just a bolt through a hole, it is a tapered bolt that wedges itself into the nut and takes some force to remove.
Good luck.
To steering system disassembly
