Crankshaft sprocket install
Old Sep 18, 2002 | 11:25 AM
scottw's Avatar
scottw
Default Crankshaft sprocket install
Is installing the crankshaft sprocket pretty straight forward or do you need a special tool?
Old Sep 18, 2002 | 11:28 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Default Re: Crankshaft sprocket install (scottw)
Length of 2" pipe and a hammer :smash: tap :smash: tap :smash: tap
Old Sep 18, 2002 | 11:29 AM
Fevre's Avatar
Fevre
Did you say sprockets?
:lol:
Old Sep 18, 2002 | 11:34 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Default Re: Crankshaft sprocket install (Fevre)
:lol:
:lol: :lol: :lol:
Old Sep 18, 2002 | 12:23 PM
Matt Gruber's Avatar
Matt Gruber
i boil them in water; they often slide right on
Old Sep 18, 2002 | 01:00 PM
RatRacer's Avatar
RatRacer
Default Re: Crankshaft sprocket install (Matt Gruber)
Same concept, I put it in the oven for 10 minutes at 400 degrees. They easily slip right on with no pounding required.
Old Sep 18, 2002 | 01:34 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Default Re: Crankshaft sprocket install (RatRacer)
Or you could put the crank in the freezer :lol:
Old Sep 18, 2002 | 03:20 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
I put the sprocket in a vise and drive the crank onto it with a sledge hammer. Hah, just kidding.
Actually, the heating method works awesome. You can also gently tap it on using a brass drift and tapping in a crossing pattern. There is a special tool that http://www.powerhouseproducts.com sells, it also works for installing harmonic balancers, very useful.
Nice picture Fevre.
To Crankshaft sprocket install
