Anybody Using a Shift Light w/Factory Tach?
Old Nov 24, 2016 | 01:40 PM
Street Rat's Avatar
Street Rat
Default Anybody Using a Shift Light w/Factory Tach?
My Autometer shift light works as it is supposed to except where I need it. At higher rpms it will not actuate. If I put a 3000 rpm pill in it works great. If I put a 5200 rpm pill in it won't come on when the factory tach reaches 5200 rpm.
I've sent the shift light in to Autometer. They returned it saying it worked fine. If I change pills to another 5200 rpm pill it still doesn't work. I've tried other higher rpm pills and they don't work either.
I have the signal wire hooked up to the white wire coming off of the distributor. I have the factory tach capacitor hooked up as well. I'm using a Davis Unified Ignition distributor on a non stock '81.
Any help is appreciated.
Old Nov 24, 2016 | 03:03 PM
'75's Avatar
'75
Have you verified the accuracy of your factory tach?
Old Nov 24, 2016 | 04:09 PM
Street Rat's Avatar
Street Rat
That I have not done.
Is there a good way to do that myself? Does it need to be pulled to be checked and corrected?
Old Nov 24, 2016 | 04:15 PM
'75's Avatar
'75
If you have a timing light with the rpm function, that's an easy tool to check with. I was thinking that if your factory tack is reading hi, then you might not be getting to the shiftlight rpm.
Old Nov 24, 2016 | 04:26 PM
Street Rat's Avatar
Street Rat
I have run it as high as 6000 rpm with no shift light activation. That's what puzzles my. Tach has been accurate with the timing light in the past.
Old Nov 24, 2016 | 04:28 PM
'75's Avatar
'75
Have you tried it with the factory tach unhooked, maybe the signal up hi isn't strong enough .
Old Nov 24, 2016 | 06:59 PM
Street Rat's Avatar
Street Rat
No I sure haven't. Something I will look at.
To Anybody Using a Shift Light w/Factory Tach?
