Caliper
Old Nov 26, 2016 | 01:52 PM
Cobfree's Avatar
Cobfree
Default Caliper
I have not driven my 68 for several months. Backed it of the garage today and no brakes. I assume one of the calipers is bad. Is there an easy way to determine which one is bad?
Old Nov 26, 2016 | 02:01 PM
hunt4cleanair's Avatar
hunt4cleanair
Get up under each wheel with a flashlight and look for a leaky caliper. Also, check the master cylinder for fluid and/or leak. It could be one or they might have formed a union and collectively united against its owner with protest and dumped fluid. You know how it is these days...everything is protested!
Old Nov 26, 2016 | 05:30 PM
lvmyvt76's Avatar
lvmyvt76
probably just need to bleed the iar out of them, must have run=out on the rotors, to get the air in the caliper.
To Caliper
