emergency-need help fuel pump
Old Sep 18, 2002 | 09:55 PM
Surfer69's Avatar
Surfer69
Default emergency-need help fuel pump
Was fixing my tach cable, turned engine with coil disconnected to see if tach was working then all of a sudden I smell gas big time. I look and my fuel pump is leaking like a siv. The engine is off but it is still leaking bad. A closer look, and it is coming out of a small hole, like a breather hole, on the top half of the fuel pump. Can someone tell me what this hole is for and is my pump shot or is there another explanation? Thanks
Old Sep 18, 2002 | 10:01 PM
ROD NOCK's Avatar
ROD NOCK
Default Re: emergency-need help fuel pump (Surfer69)
Yep, your fuel pump is shot. The little hole atop is a breather hole for the pump diaphram. When perforated, it will leak there. Remove the incoming fuel line and temp plug it, or you'll get a siphon action. Vent the area real good, and keep a pan under there to catch any drips till fixed. Good Luck -Rod :chevy
Old Sep 18, 2002 | 10:17 PM
Surfer69's Avatar
Surfer69
Default Re: emergency-need help fuel pump (ROD NOCK)
Thank you very much!
Old Sep 22, 2002 | 02:04 PM
ROD NOCK's Avatar
ROD NOCK
As I don't get many 'Thank You's' here, I wanted to reply with You're very Welcome! :D
To emergency-need help fuel pump
